151
[Survey inside] OxygenOS Open Beta 16 for the OnePlus 6 and Open Beta 8 for OnePlus 6T
  1. Priyanshu Sharma
    Jelly Bean Apr 17, 2019
    Priyanshu Sharma , Apr 17, 2019 :
    HD Calling works on 3G/4G= HD calling(Should be supported by carrier to work)
    VoLTE (Voice over LTE) Only works on 4G= HD calling+Internet at the same time.
  2. X1528117816360
    Cupcake Apr 17, 2019
  3. Adex0ne
    Ice Cream Sandwich Apr 17, 2019
    Adex0ne , Apr 17, 2019 :
    fully understood now, thanks pal
  4. Ultimodrew
    Honeycomb Apr 17, 2019
    Ultimodrew , Apr 17, 2019 :
    So they are due to releasing a update per their bi-Monthly update schedule, but how many more betas till they are ready for the stable one?
    Shajahankm likes this.
  5. KishD
    Froyo Apr 17, 2019
    KishD , Apr 17, 2019 :
    Dial *#800#* >OnePlus logkit> Function Switch> VOLTE Switch and enable it. Exit and reboot. Enhanced communications under sim settings can then be enabled.
  6. Ali Muhammadx
    Ali Muhammadx , Apr 17, 2019 :
    i already tried but not working
  7. KishD
    Froyo Apr 17, 2019
    You have to enable dial 4g networks of available. The following menus should then be available.
  8. Ali Muhammadx
    my dear i know i done both Dual 4G & Volte & VoWifi Both On But still not working.
  9. KishD
    Froyo Apr 17, 2019
    Then I would suggest the problem is with your carrier as it definitely works with both my sims.
  10. Ali Muhammadx
    my carrier said they turned on volte for my sim switch sim to any other phone to confirm so i did i check in note 8,S8 plus, iPhone X & even a mid-range Huawei Y9 in all these phones volte work but when i switched back to OnePlus 6 no volte.
  11. G_Jishnu_Diwakar_sDou
    G_Jishnu_Diwakar_sDou , Apr 17, 2019 :
    yes, I'm facing the same issue... any idea when it'll be fixed?
  12. Gary S
    Froyo Apr 17, 2019
    Gary S , Apr 17, 2019 :
    OTA update to OB16... As has been the trend for recent releases, I'm not experiencing any issues. Things run well...
  13. G_Jishnu_Diwakar_sDou
    my camera is crashing in all the apps... )stock app, Google camera port, Instagram) i still need to rest more apps... is anyone else facing this issue?
  14. Saenz4931
    Saenz4931 , Apr 17, 2019 :
    in my experience, it's WhatsApp .. uninstall and reinstall.. I had that issues many times in different device specially after flashing a ROM or restored from a backup.
  15. G_Jishnu_Diwakar_sDou
    for me it keeps crashing
  16. M1545549101241
    Donut Apr 17, 2019
    M1545549101241 , Apr 17, 2019 :
    I still have issues with the camera app. I am frustrated. I had Google camera app installed and I deleted it, but I still have the same issue. Though it might be related to having 2 camera apps installed.
  17. Adex0ne
    I have Google cam installed too, I have no issues?
  18. G_Jishnu_Diwakar_sDou
    for me it crashes on Instagram and snapchat too, i don't think it had anything to do with the number of apps installed. it's got something to do with the beta update... hope they fix it soon.*regrets enrolling into beta*
  19. G_Jishnu_Diwakar_sDou
    so what I've heard it's they test diffrent versions for different regions so that's probably why people don't all have the same issues.
  20. Adex0ne
    Well for me ,I always have Twitter freeze with in-app browser even on stable, same trait followed down to beta, that's the only issue I've got
