151
[Survey inside] OxygenOS Open Beta 16 for the OnePlus 6 and Open Beta 8 for OnePlus 6T
  1. Saenz4931
    Honeycomb Apr 18, 2019
    Saenz4931 , Apr 18, 2019 :
    I think you need to explain what's is wrong with details, also make sure make sure you are a Beta tester before you post in here. you need to give feedback to OnePlus and then explain your problem here, to see if any of us has encountered.
    Also. please, please please.. do not as or tell . fix ASAP.. this is not a one person priority.
    these is a Beta ROM which has bugs, and as a tester, you are giving feedback on the problem.
    do not expect special treatment. it will not happen, nor you will get a hot fix just for you.
    thanks
  2. Saenz4931
    wrong questions,. wrong thread
  3. Saenz4931
    You should fill out a complaint form and send it directly to OnePlus. this is a Beta thread. not a complaints box
    thank you
  4. Saenz4931
    If you are a Beta tester, that would be the last post you can think off.
    You should be knowledgeable to know that you don't have to wait.. you can simply download the full file and flash manually.
    assuming you didn't know that and at this level of Beta number, is best for you to stay away from Beta tester.
    thank you.
  5. Saenz4931
    BoianaRajaRamesh
    there is no security patch update still now from last 3 months​
    they are set for Christmas. so be patient and have a hot coco
  6. Saenz4931
    December 24th at midnight,. make sure you have a glass of milk for Santa and some ganya brownies.
    Deactivated User, GMitra and ironass like this.
  7. Saenz4931
    You should pawn or sell your OnePlus and move on with a different OEMs like the ones you are mentioned. this is not a religious marriage from the 1800, that you can't get a divorce
  8. Saenz4931
    download Google dialer and make it your default dialer.
  9. Auxqii
    Auxqii , Apr 18, 2019 :
    Lmao [e]1f602[/e]
  10. dkanjilal
    Cupcake Apr 18, 2019
    dkanjilal , Apr 18, 2019 :
  11. zoran81
    Jelly Bean Apr 18, 2019
    zoran81 , Apr 18, 2019 :
    What security reasons?!?
  12. zoran81
    ironass likes this.
  13. Lelander2015
    Gingerbread Apr 18, 2019
  14. naveen_dynamo
    Donut Apr 18, 2019
  15. Priyanshu Sharma
    Priyanshu Sharma , Apr 18, 2019 :
    First of all they haven't improvement network display. Read the changelog again, it's Network speed display.
    If your operator isn't giving good speed then how can you get? Check with different SIMs and different operators. Choose one which gives better speeds in your area.
    I've switched from Jio to my primary Airtel because that is very slow in my area now a days, earlier it was good.
    I get constant 70Mbps+ with Airtel in New Delhi, India.
  16. MikeMp
    MikeMp , Apr 18, 2019 :
    None.
  17. JelleZon
    Lollipop Apr 18, 2019
  18. TheAyushJain
    TheAyushJain , Apr 18, 2019 :
    Hey everyone , I have been running through a weird issue in this beta , my phone is rooted and these are the modules that i have installed , the issue is that I haven't been able to place calls but I am able to access the internet
    As soon as I place call it gets disconnected instantaneously , any solution for this
    Also this is the first time this issue has occurred , it never happened to me before beta 8
  19. ramesh1kr
    Eclair Apr 18, 2019
    ramesh1kr , Apr 18, 2019 :
    Priyanshu perhaps u have not read my message completely. I had already mentioned that with comparison of other devices OnePlus network speed is slow. yes I forgot to mention that of same network and same place.
  20. Priyanshu Sharma
