151
[Survey inside] OxygenOS Open Beta 16 for the OnePlus 6 and Open Beta 8 for OnePlus 6T
  1. Tudor2308
    Gingerbread Apr 18, 2019
    Tudor2308 , Apr 18, 2019 :
    Ok how about a non reflective surface like this?
    perfect lighting conditions edge detection really poor
  2. Adex0ne
    Ice Cream Sandwich Apr 18, 2019
  3. Adex0ne
  4. Yannis Neris
    ironass likes this.
  5. pilhuhn
    Cupcake Apr 18, 2019
    sowmyasrinivas06 likes this.
  6. drl431
    Marshmallow Apr 18, 2019
    drl431 , Apr 18, 2019 :
    Yeah, but the pixel 3xl is expensive and has that huge notch...
    zoran81 and ironass like this.
  7. theonly2333
    Eclair Apr 18, 2019
    theonly2333 , Apr 18, 2019 :
    The Security Update and feature update seems to be two different things. It can be a stable release with features of the previous update but with 2019.4 security build.
    Cheers.
  8. Jimmyostrom
    G_Luc_Haas_DVWl likes this.
  9. Deactivated User
    Apr 18, 2019
  10. Deactivated User
    Apr 18, 2019
  11. Deactivated User
    Apr 18, 2019
    ironass likes this.
  12. Deactivated User
    Apr 18, 2019
  13. Priyanshu Sharma
    Jelly Bean Apr 18, 2019
    Priyanshu Sharma , Apr 18, 2019 :
    Ya, sometimes it misses but still better than first one. Try shooting different objects other than that CocaCola. But I don't have this kind of issue with my OnePlus 6. Edge detection is always on point.
  14. buraksy
    Donut Apr 18, 2019
    buraksy , Apr 18, 2019 :
    How is your battery? My 6t seems to suffer from battery drain on mobile data. No problem on WiFi though.
  15. ironass
    Lollipop Apr 18, 2019
    ironass , Apr 18, 2019 :
    May indicate that you have a weak or intermittent phone signal.
    What are your -dBm and ASU showing?
    (Lower -dBm & higher ASU are better) (Turn off Wi-Fi before check phone signal)
    (Settings > About phone > Status > SIM status > Signal strength)
  16. pradip1173
  17. ironass
    Go to... Settings > About phone > OxygenOS version... what version is showing?
    pradip1173 likes this.
  18. Priyanshu Sharma
    We can expect it in 2020-2021 here in India as the testing has already started by Airtel and Huawei.
  19. pradip1173
    pradip1173 , Apr 18, 2019 :
    it is showing 9.0.4 still,no update received since then.
  20. ironass
    You are on the stock, stable, OxygenOS 9.0.4 and as per the threads title, this update is for those enrolled on the Open Beta test firmware release.
