151
[Survey inside] OxygenOS Open Beta 16 for the OnePlus 6 and Open Beta 8 for OnePlus 6T
  1. Maverick2.0
    KitKat Apr 23, 2019
    Maverick2.0 , Apr 23, 2019 :
    Explained as lucidly as possible.
    ironass and Kytharsis like this.
  2. G_Tinh_Jepsen_filK
    Cupcake Apr 23, 2019
    G_Tinh_Jepsen_filK , Apr 23, 2019 :
    Just wanted to say this is one of the smoothest build in months! Scrolling lag and frame drop is virtually gone from previous released. GJ guys!
    Kytharsis and Deactivated User like this.
  3. Y1555996920351
  4. ironass
    Lollipop Apr 23, 2019
    ironass , Apr 23, 2019 :
    Have, "fixed it", for you. :)
    NetoConcatto, fidus62 and Kytharsis like this.
  5. Y1555996920351
    fidus62 likes this.
  6. efks
    Gingerbread Apr 23, 2019
    efks , Apr 23, 2019 :
    Yes beta smooth scrooling even on Facebook not lag at all i never seen before but stable 9.0.13 not i checked 2 times
  7. malkeshav_kr
    Eclair Apr 23, 2019
  8. G_Gaddam_Praveen_lHQJ
    Shajahankm likes this.
  9. G_Leonardo_Bergamin_VXGF
    G_Leonardo_Bergamin_VXGF , Apr 23, 2019 :
    After the newest beta (Op6T), the network speed is with an bold font, different from the rest of the texts in status bar. Can roll back to the original font?
  10. G_Gaddam_Praveen_lHQJ
  11. fatehbajwa
    fatehbajwa , Apr 23, 2019 :
    I've been following threads and posts about battery issue whenever there is an update and always thought people are making an issue out of nothing.
    I feel otherwise now. I've never had the need to check my SOT or battery usage earlier as it was never an issue... Till now.
    I updated to the latest Beta and I feel there is a distinct drop in battery life... I have no clue why.
    I'm attaching screenshots of battery usage and would be grateful if the more technically oriented folks here could point out what I'm doing wrong and how I could sort this issue out.
    Thanks in advance.
  12. zoran81
    Jelly Bean Apr 23, 2019
    zoran81 , Apr 23, 2019 :
    Instagram, Facebook, Messenger and Whatsapp are well known battery hogs.
    try to clear cache of each app or try to uninstall them and see if the battery life will improve.
    ironass and fatehbajwa like this.
  13. fatehbajwa
    Will try it right now.... But I'd like to add that I've always been using these apps.... For years... What's different now... The battery drain kind of Co incided with beta update.
  14. G_Leonardo_Bergamin_VXGF
  15. habeebsahili
    Froyo Apr 23, 2019
    habeebsahili , Apr 23, 2019 :
    turn off auto sync up and check how battery goes i have similar usage as u but not that much of a drop.. battery is insane!
    fatehbajwa likes this.
  16. ironass
    The ZRAM feature in the last 3 Open Betas is causing a battery drain as discussed in this thread a few days ago.
  17. fatehbajwa
  18. ironass
    Yes... as described in the post. You will need to be rooted and have a rooted file manager and edit your build.prop file. Only for advanced and competent users.
    zoran81 and fatehbajwa like this.
  19. fatehbajwa
    So I guess for someone who isn't that technically competent..... The way out would be go back to a stable release.
  20. ironass
    That is up to you.
