132
[survey inside] OxygenOS Open Beta 17 for the OnePlus 6 and Open Beta 9 for OnePlus 6T
  1. F_Adarsh_Mishra_KykP
    Cupcake May 2, 2019
    F_Adarsh_Mishra_KykP , May 2, 2019 :
    is there any reason i am not enrolled
    who aare enrolled
  2. ironass
    KitKat May 2, 2019
    ironass , May 2, 2019 :
    See my previous post
  3. Gallois Melvin
    Cupcake May 2, 2019
  4. 1plus6T19
    Cupcake May 2, 2019
    1plus6T19 , May 2, 2019 :
    any UI improvements like larger app icons, more customizable app folder and being able to install official google camera if making it as stock cam app is not possible?
  5. L1556831554924
    Cupcake May 2, 2019
    L1556831554924 , May 2, 2019 :
    hi can any tell what the system should be taking up? mine is using 12gb. seems alot. would expect about 8gb
  6. drl431
    KitKat May 2, 2019
    drl431 , May 2, 2019 :
    Hi, so you think the os should equal the ram size, or is there another formula?
    ironass likes this.
  7. Aathif_Mahir
    Ice Cream Sandwich May 2, 2019
  8. NilanjanPaul
    Gingerbread May 2, 2019
    NilanjanPaul , May 2, 2019 :
    brother, there is nothing to do with enrolling and stuff. Just download the available Open Beta 8 full Rom from Oneplus website's support section, update your device through local upgrade and your device would be running on Open Beta 8. Then find the Beta 9 through OTA on software update section in settings and update your device to the latest Open Beta i.e. 9. Just remember though, going back from Open Beta to Stable would require a full factory reset at first and then the same procedure through local update and in this case the Stable firmware version has to be newer than the Beta version you would be using at that time, preferably you would have to skip an Beta update and then install the Stable that releases after that Beta's(the skipped one) release. Also remember, the full Rom takes more time to show up on official website, few weeks after the OTA.
  9. NilanjanPaul
    Gingerbread May 3, 2019
    NilanjanPaul , May 3, 2019 :
    The system's animations, specially the window transitions seem to be a bit more noticeable (at 1x scale) with this update. They look really beautiful and I'm loving it even more. The new UI for system updates is really awesome and highlights the term Oxygen OS beautifully. The stability is greatly improved, it seems. Great update. Loving it!!
  10. B_Wrath
    Marshmallow May 3, 2019
    B_Wrath , May 3, 2019 :
    What do you think the stock camera nightscape is for? Of you think it is similar to the night scene of gcam, you are mistaken. Stop being vague again and explain what exactly drastic change means.
    Just because someone questions you, they are fanboys? Man, this logic never ceases to amaze me.
    Seriously? Calling guys shills because we are calling you out on your BS? I can ask you, how much are the competitors paying you to talk ill of OnePlus in these forums.
    zoran81, Kytharsis and ironass like this.
  11. Stedy59
    Cupcake May 3, 2019
    Stedy59 , May 3, 2019 :
    Give it a rest... Thank you for not EVER asking for this again. Sheesh
    Neddard, zoran81 and Kytharsis like this.
  12. LegolasX
    Jelly Bean May 3, 2019
    LegolasX , May 3, 2019 :
    this is what happens when you invite every tom, dick and harry to install beta whenever they ask for stable updates. let them ask in stable thread why invite the things here?
  13. U1527746761760
    Eclair May 3, 2019
  14. NilanjanPaul
    It does show the warning....but that much heating is normal and it is what you should expect from a sdm 845 powered phone without any specialized cooling tech. Does it happen only while playin graphic intense games??
    Kytharsis likes this.
  15. U1527746761760
    Eclair May 3, 2019
    U1527746761760 , May 3, 2019 :
    while playing pubg..
  16. B_Wrath
    Heavy gaming app is causing heat?
    ironass, zoran81 and Kytharsis like this.
  17. NilanjanPaul
  18. T1528531902505
    Eclair May 3, 2019
  19. NilanjanPaul
    oh boy....always on display has still not seen the door of Beta. Believe me, AOD sucks battery a lot, even at the lowest brightness levels. It will just be a bloatware and we want our Oxygen OS to be clean and light, right? You can download the Always on Display Amoled app from Play Store and see it yourself.
    ironass and Kytharsis like this.
  20. Masum Miah
    Donut May 3, 2019
    Masum Miah , May 3, 2019 :
    I am a stable user. Should I go for beta version? I don't know lots about beta version. Again I am not facing any problems in stable version. It's ok for me. But I get update later.
