132
[survey inside] OxygenOS Open Beta 17 for the OnePlus 6 and Open Beta 9 for OnePlus 6T
  1. rishabhdmehta Cupcake May 4, 2019
  2. Ashil1312 Donut May 4, 2019
    Ashil1312, May 4, 2019 :
    i got the 9.0.5 update with security update of march on my one plus 6 , after this update Google play store is not working properly...
  3. ironass KitKat May 4, 2019
    ironass, May 4, 2019 :
    ... and you are posting this in the thread for Open Beta test firmwares OB17 & OB9 because? :rolleyes:
    Kytharsis and Maverick2.0 like this.
  4. Maverick2.0 Jelly Bean May 4, 2019
    Maverick2.0, May 4, 2019 :
    I will never understand why someone people can't even differentiate between Stable channel and Beta channel.o_O
    Kytharsis likes this.
  5. Ashil1312 Donut May 4, 2019
    ironass likes this.
  6. Maverick2.0 Jelly Bean May 4, 2019
    You know, I have been testing one app for a day now. Drains the battery though. I wonder if the drain would be lesser if it was a part of OOS.
  7. Maverick2.0 Jelly Bean May 4, 2019
    I have found a new app. The AoD is awesome and all biometric features work.
    However, it does use up a substantial amount of battery. I wonder how much you would consider acceptable considering how convenient the feature is...
  8. NilanjanPaul Gingerbread May 4, 2019
    NilanjanPaul, May 4, 2019 :
    ya evn I tried the Always on Amoled by newgen mobile, but it drains battery a lot which I couldn't consider acceptable myself. Hence I stopped using it. But your question is quite interesting "If it had been a part of the OS itself, how much the battery drain would have been?"
  9. efks Froyo May 4, 2019
  10. buraksy Donut May 4, 2019
    buraksy, May 4, 2019 :
    Nothing diffirent than when i was on ob8 tbh. And i dont use a black wallpaper.
    Battery had always been very good but since ob9 it has been better for me.
  11. Maverick2.0 Jelly Bean May 4, 2019
    Yes, that's what I have been wondering about. I mean, Samsung does a great job of integrating AoD in its One UI. Looks fantastic. Yes, it does use up more battery,but at least the option is there. Plus, one can always turn it off .
  12. LegolasX Jelly Bean May 4, 2019
    LegolasX, May 4, 2019 :
    only that OnePlus outright refuses to re-enable it.
    they decided what's good for user's battery on their own. nothing we can do.
    Maverick2.0 and NilanjanPaul like this.
  13. NilanjanPaul Gingerbread May 4, 2019
    ya one step away from monopoly
  14. NilanjanPaul Gingerbread May 4, 2019
    nevertheless it does use up a lot of battery and henceforth I myself feel its better the way users who want this have to download some app for it from the play store
  15. Maverick2.0 Jelly Bean May 4, 2019
    Yes, I was conned into buying Oneplus because everyone said they always listen to their users. But I now find that all they do is impose whatever suits their cheap business ends. Remember what happened with that headphone jack poll? The last thing they do is care about what we want.
    tortoise14 likes this.
  16. Maverick2.0 Jelly Bean May 4, 2019
    Actually, I would not mind that. It's just that I feel that if AoD is integrated into the OS, it might drain less battery.
  17. Rafa.Pez.Vela Cupcake May 4, 2019
  18. NilanjanPaul Gingerbread May 4, 2019
    definitely its a point to be considered
    Maverick2.0 likes this.
  19. NilanjanPaul Gingerbread May 4, 2019
    I think you r havin some issues with ur settings and stuff....also try clearing the cache and restarting the device once....if it doesn't work, do a factory reset....that will work for sure, just don't forget to take a backup for ur data
  20. reylimo Gingerbread May 4, 2019
    reylimo, May 4, 2019 :
    Not for me. This beta is awesome for me in battery life
    ade0410 likes this.
