82
[SURVEY INSIDE] OxygenOS Open Beta 17 for the OnePlus 7 Pro and 7
  1. genialsandeep
    Gingerbread Aug 21, 2020
  2. genialsandeep likes this.
  3. kimpang
    Cupcake Aug 22, 2020
    the_reckoner and tarun17 like this.
  4. Last edited by a moderator: Aug 22, 2020
    sidm92 likes this.
  5. sidm92
    Donut Aug 22, 2020
  6. Mdkknk
    Froyo Aug 23, 2020
    KishanGarach likes this.
  7. Mdkknk
    Froyo Aug 23, 2020
  8. Kuldeep_Naruka
    Cupcake Aug 23, 2020
  9. Swejuggalo
    Community Bug Hunter Aug 23, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Aug 23, 2020 :
    Have you checked this? Press the text and not the toggle and you see the supported apps. Depending on what you have installed it may not be many.
    Mdkknk likes this.
  10. Mdkknk
    Froyo Aug 23, 2020
    YAJIV4VIJAY and sidm92 like this.
  11. Swejuggalo
    I don't think that will kick in and do anything that very often. Most often it's simply just best to use the better network than using 2 networks.
    If that feature relies on that dual channel supported app list I don't know. There are not much detailed facts on how it is supposed to function (atleast not what I have read).
    I didn't bother to activate it once on my older 7 Pro. So one day at work it suggested to activate it when both my mobile and WiFi was limited.
    Mdkknk likes this.
  12. prth1O
    Donut Aug 23, 2020
    prth1O , via OnePlus 7 , Aug 23, 2020 :
    Does anyone having issues with wifi connectivity ,cause it not getting connected after some time while my router is still fine as issues is not being resolved even after rebooting and even my cellular network is having issues
  13. Emanuele192
    Donut Aug 23, 2020
    vaibhavvc and Ravitejanayudu like this.
  14. Last edited by a moderator: Aug 23, 2020
    Artemus. likes this.
  15. Swejuggalo
  16. Mdkknk
    Froyo Aug 24, 2020
  17. Swejuggalo
    Community Bug Hunter Aug 24, 2020
  18. gdsingh94
    Jelly Bean Aug 24, 2020
