82
[SURVEY INSIDE] OxygenOS Open Beta 17 for the OnePlus 7 Pro and 7
  1. Sundar_Srithar
    Gingerbread Sep 14, 2020
    Sundar_Srithar , via OnePlus Community App , Sep 14, 2020 :
    You're talking about the BW Z sound enhancement options right?
    Yeah, it's not there.🤦🏻‍♂️
  2. sksivakumar1
    Donut Sep 14, 2020
    YAJIV4VIJAY and I1577990398813 like this.
  3. prasad321
  4. Pa1KumarM
  5. J1577019159352
    Cupcake Sep 14, 2020
  6. Gdsingh9
    Jelly Bean Sep 14, 2020
    Artemus. likes this.
  7. Artemus.
    Nougat Sep 14, 2020
    Artemus. , Sep 14, 2020 :
    In the Community app, tap the big (+) button on the bottom right then "Feedback".
  8. YAJIV4VIJAY
  9. prasad321
    prasad321 , via OnePlus 7 , Sep 14, 2020 :
    7 pro will get updates/ security patch for atleast 2 years. So rooting phone is not good idea. Advantages are like you can control everything on phone like cpu clock speed apps on your phone etc. Rooting phone will make it more vulnerable if we are not able to control the access of each app. Experts in this group can describe more.
    YAJIV4VIJAY likes this.
  10. R.Peter
    Ice Cream Sandwich Sep 14, 2020
    R.Peter , Sep 14, 2020 :
    How rooting and regular updates are related with each other?
    Rooting provides you functionalities that the system normally restricts. For example you can automate your device's behaviour (turn off wifi, turn on mobile net, etc).
    Rooting makes your device more vulnerable if you install stuff from unauthorised or untrustworthy places.
  11. prasad321
    Bootloader is unlocked so you will not receive OTA. I read it somewhere.
  12. Ali Muhammadx
    Honeycomb Sep 14, 2020
    Ali Muhammadx , via OnePlus 7 Pro , Sep 14, 2020 :
    I am using root from when i get oneplus 6 using public beta builds & get OTA update every time when oneplus release a new public beta build now same with my oneplus 7 pro rooted & still getting public beta builds via OTA in 2 GB or 2.5 GB size.Not know about stable builds.
  13. c3drik67
    c3drik67 , Sep 14, 2020 :
    in this case you should change the reading source because it is absolutely wrong.you receive all the updates except that you receive the complete rom each time but it does not change anything
    prasad321 and YAJIV4VIJAY like this.
  14. Ali Muhammadx
    In my case i use root & root give me opportunity to use Themes so i can make supported apps to amoled dark mode which save my battery & save AMOLED panel from burn-in.Root also provide you opportunity to stop ads all around system & apps using Adaway app.
    We also can remove dead space introduce in Android 10 with navigation gestures by using magisk module.We can install themes for Gboard & change the key press sound.
  15. Ali Muhammadx
    No it's not they delay the update because OnePlus release two new devices next month according to the source.one is OnePlus 8T & second is a midrange device.They working on 8 series & making Android 11 stable for 8T series & want to launch 8T device as first device in the world & market with android 11.
    If we get beta build 18 it's a security patch only nothing fix you get until the 8T launch.If you remember they promise one hand mode for oneplus 7 series & say many time we push it in next build & that next build not release by oneplus.
    Pa1KumarM likes this.
  16. YAJIV4VIJAY
    YAJIV4VIJAY , via OnePlus 7 Pro , Sep 14, 2020 :
    But now we have dark mode support to almost all apps right? Isn't it enough? Only one thing which OnePlus 7 pro didn't reach my expectations is battery life! Though I know what is takes to give the force 90hz and qhd, superb haptic feedback etc... I want a way to save and use my battery to its full potential.
    I think if it is possible to solve this problem with rooting, then it is worth trying it!
  17. Ali Muhammadx
    All apps have grey dark mode not Amoled black is more good looking if you see in iPhone people like Amoled black instead of grey dark mode & since the removal of force dark mode for 3rd party apps from 7 series you can't enjoy a system wide level experience of black theme they remove that option from 7 series & add it to 8 series to boost sale's.
    In battery life i am a light mobile user so my battery last 18 to 20 hours with a very low usage i normally use WhatsApp for calling & chatting.i am using resolution auto switch & refresh rate 90 Hz.On Open Beta 17
  18. The_Rock90
  19. Pranjal.Goel.16 , via OnePlus 7 Pro Mirror Gray , Sep 14, 2020 :
    Rest assured, you will get next ota.
    smartbuyer likes this.
