96
[SURVEY INSIDE] OxygenOS Open Beta 3 for the OnePlus Nord
  1. KaranHalwai
    Eclair Feb 4, 2021
    KaranHalwai , via OnePlus Nord , Feb 4, 2021 :
    "Images" button is cropped under camera notch, while setting AOD wallpaper from home screen.
    If "images" option is programmed the way it is, it looks imperfect.
    Refer the screenshot attached.
    #41
    U1597910427706 likes this.
  2. KaranHalwai
    Eclair Feb 4, 2021
    By default it is not provided. But since Android 11 beta, you can disable google dialer, messaging, contacts app and install OnePlus default dialer, messaging, contacts apps.
    I am using it since Android 11 beta1. It is working very fine and smooth.
    Kudos to Oneplus developers to work on user's demand ❤️💯
    #42
  3. Mhuz
    Eclair Feb 4, 2021
    #43
    U1597910427706 and 1+noor like this.
  4. O1605694605743
    Cupcake Feb 4, 2021
    #44
  5. Tom W AU
    Donut Feb 4, 2021
    #45
  6. MotSaw
    Froyo Feb 4, 2021
    MotSaw , Feb 4, 2021 :
    If it would be lowered even more you wouldn't see sh*t.
    #46
    dikoscilator likes this.
  7. MotSaw
    Froyo Feb 4, 2021
    Which app?
    #47
  8. Y1599832449760
    Cupcake Feb 4, 2021
    #48
  9. goufy
    Eclair Feb 4, 2021
    goufy , Feb 4, 2021 :
    [QUOTE = "G_poisson_nicolas_rElw, message: 22753306, membre: 1348227"] Toujours rien .... [/ QUOTE]
    Ils doivent attendre la 6G ...:(
    #49
  10. 1+noor
    Froyo Feb 4, 2021
    1+noor , via OnePlus Nord , Feb 4, 2021 :
    End of the February or in March!
    #50
    U1597910427706 and lukiweiss like this.
  11. 1+noor
    Froyo Feb 4, 2021
    #51
  12. 1+noor
    Froyo Feb 4, 2021
    #52
  13. rayprayas03
    Ice Cream Sandwich Feb 4, 2021
    #53
  14. Sarwan.Kr
    Eclair Feb 4, 2021
    #54
  15. 1+noor
    Froyo Feb 4, 2021
    Average when you off the AOD but if you use AOD feature then it will give to 4h to 4.5h SOT.
    #55
  16. Tom W AU
    Donut Feb 4, 2021
    Tom W AU , via OnePlus Nord , Feb 4, 2021 :
    Bullshit! The minimum nits of OnePlus 7 Pro is less than 2 nits, the Nord is 8 nits. It's far too bright in the dark!
    #56
  17. saarthakgupta88
    Eclair Feb 4, 2021
    saarthakgupta88 , Feb 4, 2021 :
    Look, I get it that you need to use AOD. Trust me, you do not want to do it. It is a battery hog and will massively decrease your SOT. Its not working - fine, who cares. I care about SOT and not having to charge my device every 8 hours rather than some fancy feature which does not add any value.
    Maybe it does for you, so I apologise for thrusting my opinion. But it is what it is. If you enable AOD, your SOT will go for a toss.
    #57
  18. Ganesh_S_
    Gingerbread Feb 4, 2021
    #58
  19. MotSaw
    Froyo Feb 4, 2021
    No problem here, checked with Messenger and Google Messages.
    #59
  20. darkz_eye
    Eclair Feb 4, 2021
    #60
