96
[SURVEY INSIDE] OxygenOS Open Beta 3 for the OnePlus Nord
  1. Balaji2828
    Ice Cream Sandwich Feb 4, 2021
    #81
    neetx10 and U1597910427706 like this.
  2. RajasekaranK
    Eclair Feb 4, 2021
    #82
  3. sandy_yp_7
    Gingerbread Feb 4, 2021
    #83
  4. Fast_and_Curious , via OnePlus Nord Blue Marble , Feb 4, 2021 :
    In case you missed it before purchasing the nord. It originally came with google communication suite and was rightly advertised, but you missed it. So here is a screenshot of it.
    #84
    acetone802000 likes this.
  5. B1610010717379
    Cupcake Feb 4, 2021
    B1610010717379 , via OnePlus Nord , Feb 4, 2021 :
    That would be bad - still too many bugs - better to release it when it's truly ready, not in a hurry
    #85
  6. F_Varun_Darak_zMhX , via OnePlus Nord , Feb 4, 2021 :
    I think that no matter how many beta updates they give there would be some sort of bug which will appear.
    #86
    rayprayas03 likes this.
  7. SURENDRAPANDEY
    Cupcake Feb 4, 2021
    #87
  8. rayprayas03
    #88
  9. rayprayas03
    rayprayas03 , via OnePlus 7 , Feb 4, 2021 :
    Completely Agree with u
    #89
    U1597910427706 likes this.
  10. rayprayas03
    #90
  11. #91
  12. Navikanjsob
    Froyo Feb 4, 2021
    Navikanjsob , Feb 4, 2021 :
    [QUOTE = "NekoKurumi, post: 22753510, član: 3727313"] Učinili su to jer Nord ima problem sa zelenkastom bojom, da bi uklonili taj problem, povećali su svjetlinu. [/ QUOTE]
    Nord nema prNord has no problem with the green color this is solved in the settings to adjust the color you have the image white leave iradi
    #92
  13. Navikanjsob
    Froyo Feb 4, 2021
    Pozdrav, današnje beta ažuriranjeHello, today's update of the beta version of OPB3 interrupted the support for 5G in the device itself, while the version before was ok. Now I reported an error for the support of the device for 5G, Croatia has 5G HT-mobile
    #93
  14. abhisekbit
    Cupcake Feb 4, 2021
    #94
  15. Hitler812
    Eclair Feb 4, 2021
    Hitler812 , via OnePlus Nord , Feb 4, 2021 :
    I'm experiencing the same issue with Signal app
    #95
  16. #96
  17. CyberGhost03
    Froyo Feb 4, 2021
    CyberGhost03 , via OnePlus Nord , Feb 4, 2021 :
    But I can't able to disable contacts app bro
    #97
  18. CyberGhost03
    Froyo Feb 4, 2021
    #98
  19. ashishlp007
    ashishlp007 , via OnePlus Nord , Feb 4, 2021 :
    Not directly
    Os10 - open beta 1 - open beta 2 and then open beta 3
    #99
  20. Khanboy1432
    Cupcake Feb 4, 2021
    Khanboy1432 , via OnePlus Nord , Feb 4, 2021 :
    Issues found :-
    1. Canvas AOD still not working.
    2. On opening quick settings panel. The notification icon area is grey instead of black.
    3. Chat bubbles still not working properly.
    Vishnu.Zmr and U1597910427706 like this.
