3
Switch between devices in OnePlus Buds Z via OnePlus 7T
  1. manasgupta017
    Froyo Nov 11, 2020
    manasgupta017 , via OnePlus 7T , Nov 11, 2020 :
    I have recently purchased OnePlus Buds Z , I successfully connected with my laptop and phone but not able to switch between both the devices.
    Is quick switch not supported by Buds Z ?
  2. Q1571998310247
    Donut Nov 11, 2020
    Q1571998310247 , Nov 11, 2020 :
    facing the same issue. also sound is very low when used with oneplus 7 mobile device
  3. Rajendra.Bhat
    Jelly Bean Nov 11, 2020
  4. manasgupta017
    Froyo Nov 11, 2020
    In volume section it's doing fine, try increasing volume from laptop.
    But quick switch is kind of a need to me bcz sometimes buds are connected to laptop and I need to take call on phone or vice versa.
    Buds Z has some connection issues with laptop as it disconnects for 10-15 sec after long usage.
    With my device it sometimes pauses for 2-3 sec and then again starts to work fine.
    PS: using it on my OnePlus 7t
  5. manasgupta017
    Froyo Nov 11, 2020
  6. manasgupta017
    Froyo Nov 11, 2020
  7. manasgupta017
    Froyo Nov 11, 2020
  8. Q1571998310247
    Donut Nov 11, 2020
    ain't you feel low sound in buds z when connected to
    oneplus phone compare to other devices.
  9. manasgupta017
    Froyo Nov 11, 2020
    I haven't been so observant, but they seemed to work fine with laptop and mobile.
    Took long duration call on laptop it was fine.
    But yes the call volume on my phone is low as compared to laptop.
    Q1571998310247 likes this.
  10. Q1571998310247
    Donut Nov 11, 2020
    even the music volume is low on mobile compare to laptop and other non op devices
  11. manasgupta017
    Froyo Nov 11, 2020
    After reading your comment I cautiously heard the Buds Z on laptop and then on phone , the difference is there but can be neglected. Not very low
  12. Q1571998310247
    Donut Nov 12, 2020
    Q1571998310247 , Nov 12, 2020 :
    can you please share me the sound settings in your mobile for buds
  13. manasgupta017
    Froyo Nov 12, 2020
    manasgupta017 , via OnePlus 7T , Nov 12, 2020 :
    It's simple,
    Under sounds and vibration:
    I am using dynamic mode for Dolby Atmos
    There is an option for earphone adjustment which is enabled when buds z are connected, it's turned off bcz it kill a bit of surround sound of buds and increases the bass a little. Which in turn affects the other components of the song.
    That's it.
  14. Daanesh Kejriwal
    Cupcake Nov 16, 2020
    Q1571998310247 and manasgupta017 like this.
  15. vaibhavbkale
    Cupcake Apr 1, 2021
    vaibhavbkale , Apr 1, 2021 :
    I am still not able to quick pair between my laptop to oneplus nord and vice versa.... tried 3 seconds tap and hold on both buds
