Switch data card connectivity issues Android 10
  1. harshjn04
    Donut Jun 2, 2020
    harshjn04 , Jun 2, 2020 :
    Hi,
    with the latest update to Android 10 the switch data card is having connectivity issues with mobile data.
    if you switch the data sim to sim2 then mobile data does not work unless you reboot tue device.
    This is vice versa so by default only 1 sim will data internet working and switch data card to another sim is not connecting to internet.
    Avinash_Parida likes this.
  2. L1577495230478VJ
    Cupcake Jun 5, 2020
    L1577495230478VJ , Jun 5, 2020 :
    Finally my issue has been fixed by disabling work profile which was configured for my office purpose. I don't know how this internally blocks data card switch, but this works for me .try this .
    Nirmal_Singh_Rex and harshjn04 like this.
  3. harshjn04
    Donut Jun 5, 2020
    harshjn04 , Jun 5, 2020 :
    thank you so much
    i also had work profile, disabled it and the switch works
    crazy :)
    do you know of this might be fixed?
    L1577495230478VJ likes this.
  4. L1577495230478VJ
    Cupcake Jun 5, 2020
  5. Nirmal_Singh_Rex
    Eclair Jun 11, 2020
    Nirmal_Singh_Rex , Jun 11, 2020 :
    Any other ideas.. Bcs need work profile too.. If i disable it works if i switch on same persisting.. [e]1f622[/e]
  6. dwdhu
    Cupcake Jun 12, 2020
    dwdhu , Jun 12, 2020 :
    +1
    Mobile data not working (or fkn very slow) after dirty flashed the Android 10 on OnePlus 5T.
    I think the problem is all the APN settings is greyed out, cannot change, add or save it.
    The phone is rooted, and after TWRP downgrading to Android 9 everything is working fine so the problem is on the Android 10.
    Please urgently fix it!
  7. Oneplus5_Mikhil
    Cupcake Aug 15, 2020
    Oneplus5_Mikhil , Aug 15, 2020 :
    you can go to google device policy app and there you can click on not create work profile
