System lag
  1. Harshit_Goyal Cupcake Jun 18, 2019
    dareknowak likes this.
  2. stark2991_PL KitKat Jun 18, 2019
    stark2991_PL, Jun 18, 2019 :
    In what app?
  3. Harshit_Goyal Cupcake Jun 18, 2019
  4. stark2991_PL KitKat Jun 18, 2019
  5. Harshit_Goyal Cupcake Jun 18, 2019
  6. dareknowak Froyo Jun 23, 2019
  7. dareknowak Froyo Jun 23, 2019
    dareknowak, Jun 23, 2019 :
    "Timestamps" to see that animation frame rate drop:
    from 1minute 20 seconds. it lasts for 2-3 seconds
    from 1minute 30 minutes. ! it lasts 2-3 seconds
    from 0minute 17 seconds ! it lasts for at least 3-4seconds
  8. stark2991_PL KitKat Jun 24, 2019
    stark2991_PL, Jun 24, 2019 :
    I can see some slowdowns, but I'm not sure if there are framedrops too. It looks like the animation is being displayed in a slower rate.
    When did it start to happen?
  9. dareknowak Froyo Jun 24, 2019
    dareknowak, Jun 24, 2019 :
    it's due 60fps GoPro footage. In person it looks horrible. Started to occure since 9.0 update. I'm back on Oreo. smooth as butter since two weeks!
  10. stark2991_PL KitKat Jun 24, 2019
    Some people were reporting lags and stuttering after Pie update. No fix so far.
    dareknowak and DhruvRajani like this.
  11. Akhshay Srinivasan Nougat Jun 25, 2019
    Akhshay Srinivasan, Jun 25, 2019 :
    Try uninstalling Op launcher and reinstalling it again.
  12. stark2991_PL KitKat Jun 25, 2019
    stark2991_PL, Jun 25, 2019 :
    You can't uninstall it.
  13. Akhshay Srinivasan Nougat Jun 26, 2019
    Akhshay Srinivasan, Jun 26, 2019 :
    Indeed yes but it's something like uninstalling chrome. If you uninstall chrome, it does begin from the cover page and so is OpL.
  14. dareknowak Froyo Jun 27, 2019
    dareknowak, Jun 27, 2019 :
    Uninstalling apps, clearing data of apps, cache of apps, wipe system cache etc. etc. It does not help, that animation frame rate drop comes back. I tried all logic solutions and failed. Rolled back to Oreo and it is smooth since 3 weeks!
  15. daniel.nbo Cupcake Jul 2, 2019
    daniel.nbo, Jul 2, 2019 :
    I've been experiencing this micro lags often for at least the last 4 months. I have a 5T and I'm using the stable os.
    It happens really often, not only when going back to home screen. Sometimes it happens during some random scrolling inside apps and after a few movements later it simply gets smooth again. Its pretty weird.
    dareknowak and U1513064557294 like this.
  16. U1513064557294 Cupcake Jul 2, 2019
    U1513064557294, Jul 2, 2019 :
    yeah it happens with my device too. Facing this issue since pie update.
  17. dareknowak Froyo Jul 4, 2019
    dareknowak, Jul 4, 2019 :
    Correct. There are many posts like yours. I hope they are working on the issue right now. I wish I'd had more time I would spend it with someone from OP team to find the root cause of that problem. I've rolled back to oreo and since 3+ weeks system works like a charm, no stuttering in animations aka lag, aka frame drop of animations in the launcher or within the various applications.
