system lags via OnePlus 6T Mirror Black
  1. #1
    Caomhin likes this.
  2. Kytharsis
    Marshmallow Dec 10, 2019
    Kytharsis , Dec 10, 2019 :
    Okay. You gonna give us more to chew on or is that it?
    Caomhin likes this.
  3. keithnyc
    Marshmallow Moderator Dec 10, 2019
    keithnyc , Dec 10, 2019 :
    Hiya mate, it would be really helpful if you gave a bit more information other than "the system lags". What exactly is happening, what are the specific differences you notice between now and before the update etc? If you give a bit more information (like @Kytharsis asked for...), folks might be better able to help you....
    Caomhin and Kytharsis like this.
  4. Caomhin
    Jelly Bean Dec 10, 2019
    Caomhin , via OnePlus 6T Mirror Black , Dec 10, 2019 :
    Give it a bit of time, if you have only just updated, Android is still optimising apps. Sometimes it can take a bit of time. Restart your phone a couple of times over the next couple of hours, run through 1 or more charge cycles. You will find that many issues will correct themselves.
    The likes of some Google apps such as Playstore will update in the background. It can just take a little time for the sequence to complete and settle down.
    It's just Android 10 doing it's thing.
    Kytharsis likes this.
