G1602003152836 , via OnePlus 9 , Jan 19, 2022 : Plz suggest me what should i do since My system is almost over . Now i didn't take any pictures and didn't save any documents. Plz help me .
Gamingtime1121 , via OnePlus 9 , Jan 19, 2022 : It seems like there is no permanent fix for this issue from Oneplus but you can try these Dial: * # 800 # and click on oneplus logkit. Choose delete history record and confirm the process. Another thing that helps is to delete cache files that coexist within the gallery specifically from the OnePlus recycle bin . Just make sure not to delete somethingelse . •Access the File Manager and follow the path: Android> data> com.oneplus.gallery> files> recyclebin. •Select the folder and delete it completely. Make sure to backup your data first and contact Oneplus support center as well for this issue.
