system storage is 27 gb
  1. Dasari Vamsi Krishna Eclair May 19, 2019
  2. nabbed Ice Cream Sandwich May 19, 2019
    nabbed, May 19, 2019 :
    2-3GB. It doesn't change much between versions of the OS.
  3. nabbed Ice Cream Sandwich May 19, 2019
    There's no unwanted Oreo system files - the other guy was talking bs.
  4. S1545458362819 Cupcake May 19, 2019
  5. nabbed Ice Cream Sandwich May 19, 2019
  6. S1545458362819 Cupcake May 20, 2019
  7. Maverick2.0 Jelly Bean May 20, 2019
    Maverick2.0, May 20, 2019 :
    Who exactly do you think is lying or is misinformed?
    drl431 likes this.
  8. Sharry7 Ice Cream Sandwich May 21, 2019
    Sharry7, May 21, 2019 :
    Use sd maid maybe? System analyser feature is great to recognise oversized junk.
  9. Dasari Vamsi Krishna Eclair May 21, 2019
  10. Pulikanti Tarun Gingerbread May 21, 2019
    Pulikanti Tarun, May 21, 2019 :
    By default the Android Pie OS or the system takes up 11 GB.... if its showing you over 20GB you need to clean up or remove the Junk files. The best method to do it is to use the Files Go app from Google i use a 256 GB OP6 and also 256GB OP7pro never used over 15% of storage as everything backs up on google drive and use mostly streaming services
    Raresch and Afzal Khan like this.
  11. Afzal Khan Jelly Bean May 21, 2019
    Afzal Khan, May 21, 2019 :
    Could you please post the screenshot of your storage page here for all of us to see...because if you are correct and @Kytharsis is lying then we must be living under the stone and you are about to reach a different galaxy altogether.
    Kytharsis likes this.
  12. Afzal Khan Jelly Bean May 21, 2019
    We need the proof. Post your screenshot here.
  13. Sharry7 Ice Cream Sandwich May 22, 2019
    Sharry7, May 22, 2019 :
    Check on play store.
  14. nabbed Ice Cream Sandwich May 22, 2019
    nabbed, May 22, 2019 :
    What are you even talking about? Proof of what? Have you even been following this thread?
    The guy said that to free up storage on his phone he needed to "format" the phone.
    Meaning factory reset. Because of some leftover Oreo extra files that are no longer needed, which don't exist in real life.
    That is NONSENSE. People who advocate for factory resetting to solve any trivial problem, which can be solved in minutes while preserving all of their apps and settings, are usually idiots.
  15. Liehjan KitKat May 22, 2019
    Liehjan, May 22, 2019 :
    You can use Googles files GO app from playstore to locate big unwanted filed.
  16. Maverick2.0 Jelly Bean May 22, 2019
    Maverick2.0, May 22, 2019 :
    You know, I am always skeptical about these file cleaning apps/features. What if they delete something very important? Just saying.
  17. Liehjan KitKat May 22, 2019
    The app just lists the files, it's the user who deletes them.. But it won't find old Oreo files tho, so if old system files are the issue OP is having then @Kytharsis solution is the best one.
    EDIT: I'm also skeptical about cleaning apps in general, but this one is at least made by Google :)
    drl431 and Kytharsis like this.
  18. Afzal Khan Jelly Bean May 22, 2019
    Afzal Khan, May 22, 2019 :
    Please drag down to the end before taking the screenshot..where it shows us the System. Then we will see who is the Idiot here.
    #38
  19. nabbed Ice Cream Sandwich May 23, 2019
    nabbed, May 23, 2019 :
    Well, according to you yourself, you are the idiot.
    You didn't even read the thread to gain understanding of what the issue was. Next time, please do.
    #39
  20. nabbed Ice Cream Sandwich May 23, 2019
    Do you really think that Oneplus developers would make an update for the OS to Pie and accidentally leave old, now unused Oreo files to clutter storage? Such notion is ridiculous, as is the suggestion to Factory Reset as being the best solution to free up space.
    #40
