11
System Storage
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jul 28, 2021
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Jul 28, 2021 :
    Android 11 and scoped storage makes some stuff restricted. This app has not been updated for some time. Maybe something else can show it more clearly. Will see if some other up can show more.
  2. Kaisar206
    Cupcake Aug 1, 2021
  3. mahie99
    Eclair Aug 2, 2021
  4. Kaisar206
    Cupcake Aug 2, 2021
  5. Z1627954884644
    Cupcake Aug 3, 2021
    Z1627954884644 , via OnePlus 8T , Aug 3, 2021 :
    I cannot get my storage to clear. I have deleted every file, every photo and all unnecessary apps and it has not made a difference. I have only had this phone for a few months and this is becoming very frustrating. What can I do to fix it?
  6. Z1627954884644
    Cupcake Aug 3, 2021
    Hey!! I MIGHT have a solution! If you have a lot of video and photo files you deleted, go to "gallery" > "collections" > scroll to the bottom and hit "recently deleted" and then click the little broom in the top right corner! I went from 214gb used to 42.39 gb used. I hope this is what you needed. I figured that out after deleting EVERYTHING OFF my phone. When really it's just the trash folder for all of our photos and videos that is in a very inconvenient spot.
  7. J1600680989431
    Cupcake Aug 7, 2021
  8. thechangingtime
    Honeycomb Aug 10, 2021
    thechangingtime , via OnePlus 8T , Aug 10, 2021 :
    You can see inside the System files as long as you have rooted your device and are using a root file browser. But if you do not have a rooted device, then a root file browser will be unable to see them system files.
  9. warrior143
    Ice Cream Sandwich Aug 10, 2021
  10. theshinybeast
    Marshmallow Aug 10, 2021
    theshinybeast , Aug 10, 2021 :
    No, it's not.
  11. warrior143
  12. Jackery0308
    Cupcake Aug 15, 2021
    Jackery0308 , via OnePlus 8 Pro , Aug 15, 2021 :
    Great... The issue not solved yet from April till August
    OnePlus, Never Settle for all issue!
    I bought around a year and keep making lots of issue with my OnePlus 8 Pro, Never go for OnePlus again!
    C1629355537056 likes this.
  13. Abhishek@nord
    Honeycomb Aug 15, 2021
    Abhishek@nord , Aug 15, 2021 :
    On my OnePlus Nord as I remember when it was on OxygenOs 10, it occupied 25 GB of system storage and when I updated to OxygenOs 11, it rose to 26 GB and then it got dynamic like someday it would show 26 GB and the other day 27 GB and this goes on.......
  14. H1599456822548
    Cupcake Aug 18, 2021
  15. C1629355537056
    Cupcake Aug 19, 2021
    C1629355537056 , via OnePlus 9 Pro , Aug 19, 2021 :
    Same problem, I have made 4 factory resets + had a remote session with the OP support team. They flashed my phone, but after a few days the system storage starts again to increase. Now I should collect logs for the technical team, but Im not aware how this will help .. I'm very sad that many faces this issue, normal phone usage is not possible, if you have to reset your phone each week
