System UI keeps crashing
  1. nianaris
    Cupcake May 12, 2021
    nianaris , May 12, 2021 :
    I have the OnePlus 8 5G UW IN2019, and since I updated it to IN2019_15_210312 the phone has been sluggish with the System UI crashing a lot, prior to the update the phone ran perfectly. On top of that apps that ran perfectly fine started to crash if it wasn't the System UI, I have to use my phone for work but the constant crashing is making it hard.
    Is there a temporary fix until an update comes to fix it that doesn't involve a factory reset?
    Ajin_Grace_Thomas likes this.
  2. Tokolozi
    Most Original Avatar May 12, 2021
    Tokolozi , May 12, 2021 :
    try something easy like just clearing the device cache in recovery first.
    I also heard that it may help to turn off ram boost in settings.
    Caoimhín likes this.
  3. hbk1402
    Jelly Bean May 12, 2021
  4. Caomhin
    OnePlus 9 Series Expert Community Expert May 13, 2021
    Tokolozi likes this.
  5. nianaris
    Cupcake May 13, 2021
    nianaris , May 13, 2021 :
    I thought I had updated my launcher to 5.1.4 but it was on 5.1.3. Updated it, cleared cache, restarted my phone. I also cleared the cache in recovery mode, hopefully that fixes the issue. Thanks for the suggestions!
  6. nianaris
    Cupcake May 14, 2021
    nianaris , May 14, 2021 :
    Unfortunately those attempts didn't help. I may end up having to factory reset my phone because that update is so horrible.
  7. Caomhin
    OnePlus 9 Series Expert Community Expert May 14, 2021
    Caomhin , via OnePlus 9 Pro , May 14, 2021 :
    After Backing up, full Erase All Data factory Reset might be the best option.
    Let us know how that goes for you.
    hbk1402 likes this.
  8. Yashhsai420
    Cupcake May 15, 2021
  9. Vipera ursinii macrops , via OnePlus 8 , May 16, 2021 :
    It will not help, I did 4 factory resets, and I still have that problem with crashing and lag and freezing....
