System ui not responding
  1. mohit227
    Cupcake Oct 19, 2020
    mohit227 , Oct 19, 2020 :
    So this thing started a couple of weeks ago. While I'm playing codm and I get a call. My phone gets freezed. Power button to doesn't work. Stays like that for a while then screen light up with notification of system ui not responding. Already wiped cache in safe mode. Rebooted multiple times.
    Pranav_kumar902 likes this.
  2. Rajendra.Bhat
    Jelly Bean Oct 19, 2020
    Rajendra.Bhat , Oct 19, 2020 :
    Tried factory reset?
    Check this it might help you https://drfone.wondershare.com/andr...~:text=Another reason for the Android,android.
  3. mohit227
    Cupcake Oct 20, 2020
  4. Caomhin
    Marshmallow Oct 21, 2020
    Caomhin , via OnePlus 6T , Oct 21, 2020 :
    Reset the Network adapters, possible issue between them.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth
    See if that helps.
    Tokolozi likes this.
  5. mohit227
    Cupcake Oct 21, 2020
    mohit227 , Oct 21, 2020 :
    Done. Will see couple of days if it helps.
    Caomhin likes this.
  6. mohit227
    Cupcake Oct 22, 2020
    mohit227 , Oct 22, 2020 :
    Did not help.
