OxygenOS System Update and Phone Performance
Is OnePlus killing its old versions slowly (by bugging them via system updates) to promote the new o
  1. Yes
  2. No
Results are only viewable after voting.
  1. Dewangan_Nishit
    Cupcake Feb 27, 2020
    Dewangan_Nishit , Feb 27, 2020 :
    My OnePlus 6 has started hanging quiet often and has become slow after I updated it with Android 10. At times, it gets locked and doesn't open. I have cleared cache and also the storage has a lot of space empty.
    Also I feel that the camera quality has gone down.
    Is OnePlus killing its old versions slowly (by bugging them via system updates) to promote the new ones?
    V1575976783900 likes this.
  2. Caomhin
    KitKat Feb 27, 2020
    Caomhin , via OnePlus 6T , Feb 27, 2020 :
    As per @Sufwan, Go to Settings > Apps & notifications > see all apps > select three dots > Reset app preferences.
    Then reboot.
    This will not delete your apps data but you will have to provide permissions again.
    Also just in case there is an App hogging resources, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
    xnutzii likes this.
