21
System update for OnePlus TV Q1 and Q1 Pro [V1.6.0T1910111117]
  1. RohitTheDevil
    Froyo Nov 29, 2019
    RohitTheDevil , via OnePlus 6T , Nov 29, 2019 :
    I am also facing the same issue with Eros app is not opening and working at all. Please fix it.
  2. Venky61
    OnePlus TV Expert Nov 30, 2019
    Venky61 , Nov 30, 2019 :
    Hi... can you share the Local Dimming settings? It obviously looks weird that the dimming is uneven.
    Have you guys logged in with the Oneplus Account? if not do that try again.
    If it doesn't work even after that,
    Go to Settings< Apps< See All Apps< Eros Now< Clear Data.
    Login again with Oneplus credentials.
    Let me know if it works.
    RohitTheDevil likes this.
  3. timmureddy
    Eclair Nov 30, 2019
    timmureddy , via OnePlus 7 Pro , Nov 30, 2019 :
    Hi Venky,
    Local dimming was set to high when these pics were taken. Even when i boot up backlight is firing at uneven places and spreading accross the screen when Google or oneplus logo comes up.
    Venky61 likes this.
  4. Venky61
    ok... can you check once by keeping Local Dimming to off... That way the software issues can be isolated.
  5. G_Ranjit_Das_BZIQ
    Cupcake Nov 30, 2019
    G_Ranjit_Das_BZIQ , via OnePlus 7 , Nov 30, 2019 :
    Venky I tried the steps you mentioned but still I am facing the same issue with Eros Now
  6. ddhoot83
    Eclair Nov 30, 2019
  7. ddhoot83
    Eclair Nov 30, 2019
  8. Venky61
    That's strange... Ok Try uninstall Update option in the App Settings.... If even that doesn't help, Reset should do the trick... but I would suggest to wait if you can till the next update as many a times the update resolved such errors.
  9. timmureddy
    Eclair Nov 30, 2019
    Venky61
    ok... can you check once by keeping Local Dimming to off... That way the software issues can be isolated.​
    Even with local dimming off its the same issue. Should i wait for next update or get in touch with Amazon to arrange a technician visit.
  10. Venky61
    Light bleeding is generally a known issue for the regular LED panels but in this case it's prominent towards the left top corner... It's not the same with other units but yes varies with unit to unit. I would suggest to do a reset if it's ok for you and if it still exists then you can think of contacting the CS for technician.
    But do note that the uneven patches is a normal thing for this panel with Local Dimming Off.
  11. timmureddy
    Eclair Nov 30, 2019
    Venky61
    But do note that the uneven patches is a normal thing for this panel with Local Dimming Off.​
    i did reset now and it's still the same. I will wait for next update as multiple users have similar issue and i think it can be fixed via updates as this was not there when i bought the tv.
    Venky61 likes this.
  12. vicky3572
    Eclair Dec 1, 2019
  13. ddhoot83
    Eclair Dec 1, 2019
  14. T1542136344865 , via OnePlus 7 Pro , Dec 1, 2019 :
  15. T1542136344865 , via OnePlus 7 Pro , Dec 1, 2019 :
  16. ddhoot83
    Eclair Dec 2, 2019
  17. Venky61
    OnePlus TV Expert Dec 2, 2019
  18. T1542136344865 , via OnePlus 7 Pro , Dec 2, 2019 :
    Thread cannot be found! I understand that this is the first new product launch for the developers but this was quite unexpected from Oneplus! I'm sure you guys are working hard for the update but these things should have been resolved before launching the product!
  19. Venky61
    Venky61 , Dec 2, 2019 :
    Could not be found :-o Ok you can check the Q&A post, it's the 3rd one.
    https://forums.oneplus.com/threads/oneplus-tv-questions-answers.1109814/
    And yes, I agree with your point. Most of the issues could have been sorted before the launch itself.
    T1542136344865 likes this.
