21
System update for OnePlus TV Q1 and Q1 Pro [V1.6.0T1910111117]
  1. Leon J.
    OnePlus TV Software Engineer Staff Member Dec 2, 2019
    Leon J. , Dec 2, 2019 :
    Could you please check the statement of local dimming when it goes wrong? If the statement is off, you can reset to the statement "medium", then check if it goes well
    Venky61 likes this.
  2. timmureddy
    Eclair Dec 2, 2019
    timmureddy , via OnePlus 7 Pro , Dec 2, 2019 :
    Hi Leon,
    I've tried from off to high and did not see any difference. After reset of TV it's reduced but it's very much there. Its happening only on the left top corner.
    Venky61 likes this.
  3. Angela C.
    OnePlus TV Multimedia Leader Staff Member Dec 2, 2019
    Angela C. , Dec 2, 2019 :
    timmureddy Thank you very much for your feedback!
    Could you help provide more detail informations about this problem?
    You can try to select the audio out to Digital PCM or Digital Legacy.
    Setting ==>Sound ==>Audio Out ==> Digital PCM / Digital Legacy
    The audio sound output can only be on one channel,speaker or sound bar.So, if you want to make the audio sound output by the speaker when you plug in a soundbar device, you can change the audio out to Speaker.
    Venky61 likes this.
  4. G_Ranjit_Das_BZIQ
    Cupcake Dec 2, 2019
    G_Ranjit_Das_BZIQ , via OnePlus 7 , Dec 2, 2019 :
    One more issue I am observing during scenes with fast motion, I noticed a number of artefacts due to motion interpolation in scenes with rapid motion action scenes or fast camera.Please guide how to deal with this issue?
  5. Snehanshu090
    Eclair Dec 2, 2019
    Venky61 likes this.
  6. Snehanshu090
    Eclair Dec 2, 2019
  7. Snehanshu090
    Eclair Dec 2, 2019
  8. vickyboss05
    Cupcake Dec 2, 2019
    vickyboss05 , via OnePlus 5 , Dec 2, 2019 :
    when tv is connected to external speakers via Bluetooth.. tv speakers goes off.. PL give an option to use both tv speakers and external speakers.. simultaneously
    And I request to give keyboard support to other applications too when connected via connect app
  9. Mulk Raj Anand
    Cupcake Dec 3, 2019
    Mulk Raj Anand , Dec 3, 2019 :
    I still haven't got the new ota2 update in q1...why are they posting this if they haven't released it already?...!!
  10. timmureddy
    Eclair Dec 3, 2019
    timmureddy , via OnePlus 7 Pro , Dec 3, 2019 :
    Ah ok, In my earlier TV i had an option to use both so thought it was an issue.
    Venky61 likes this.
  11. Venky61
    OnePlus TV Expert Dec 3, 2019
    Venky61 , Dec 3, 2019 :
    Hi... The Ultra Smooth Motion is suitable majorly for videos that are shot on higher FPS. If the option is turned on for normal videos/movies that are shot at 24fps, you ought to get the Soap Opera Effect and the motion blur during fast action/movement scenes. Because interpolation is literally pushing extra frames that don't exist. Do share a video if possible showing the issue you are facing for better understanding if we are talking about the same thing.
    Best Utilization of the Ultra Smooth Motion is for Sports and Documentaries that have been shot at high fps.
    Looks like the post has gone live early by mistake.... But as it's clear from the picture that update is actually around the corner and that too with Netflix, a little more wait is required I guess ;)
    Hi,
    I am not aware of any TV that can provide audio simultaneously to a Bluetooth device and an internal speaker that's wired. Please enlighten me if you know any such device.
    And yes, keyboard inclusion in more apps is required. The team is trying to contact the Apps for taking permission for inclusion.
  12. manishsoni17
    Donut Dec 3, 2019
  13. Catherine W.
    OnePlus TV Software Engineer Staff Member Dec 3, 2019
    Catherine W. , Dec 3, 2019 :
    Well,thanks for your advice,we will take it when necessary.
    vickyboss05 likes this.
  14. vicky3572
    Eclair Dec 3, 2019
    vicky3572 , Dec 3, 2019 :
    When will be the next update sir
    November passed
    Now December 3days also completed
    When we will get update boss
    Dissapointing day by day
  15. RGVEDA
    Gingerbread Dec 3, 2019
    RGVEDA , Dec 3, 2019 :
    Do as a favour and sell the TV. Your almost everyday whining is exhausting...
  16. vicky3572
    Eclair Dec 3, 2019
    It's not 20k 30k tv to take lyt
    70k tv this is not a small budget tv high budget tv
    One or two issues not more than 10issues
    You people only said
    November end end update will come wait for November end now December first week also going onnn
    No update till now
    Don't talk over
    Be in your limits
    Give the update info when releasing.if you don't know then keep calm
    Don't talk over again m saying be in your limits do your work.
    This is not 10-20k tv to take easy or light silly mindit
  17. Venky61
    Please check this, a team member has confirmed that the update should be rolling by the weekend.. Just a few more days :)
    vicky3572 likes this.
  18. vicky3572
    Eclair Dec 3, 2019
    Thank you
