21
System update for OnePlus TV Q1 and Q1 Pro [V1.6.0T1910111117]
  1. #61
    vicky3572 likes this.
  2. #62
  3. Q1571473619021 , via OnePlus Community App , Oct 26, 2019 :
    just got the update. Man those motion smoothing on Dolby vision content is still hurting my eyes. such disappointment will have to watch Netflix and prime on Ps4 pro just to avoid those forced motion smoothing on Dolby vision
    #63
  4. Subashdobby
    Gingerbread Oct 26, 2019
    #64
  5. Q1571473619021 , via OnePlus Community App , Oct 26, 2019 :
    yes but it also support Dolby vision on firestick. but unfortunately Dolby vision has those motion smoothing thing which you can not turn off like other modes
    #65
    Venky61 likes this.
  6. Subashdobby
    Subashdobby , via OnePlus Community App , Oct 26, 2019 :
    then try using inbuilt prime app. also try adjusting motion smoothness option in settings from home ui, then switch to firestick
    #66
  7. Last edited: Oct 27, 2019
    #67
    Q1571473619021 likes this.
  8. shubham54000 , via OnePlus Community App , Oct 26, 2019 :
    I recently purchased OnePlus TV Q1 (55"), using Samsung Galaxy Note 9, everytime I try to mirror my mobile screen, TV shows in "Smart View" but does'nt connect. Tried Several Times, even Reset OnePlus TV, but still not working, downloaded OnePlus TV "Connect" App and tried through it but no luck, Both Mobile and TV are connected with same Wifi Router, Any help and suggestions please?
    #69
  9. vicky3572
    Eclair Oct 26, 2019
    vicky3572 , Oct 26, 2019 :
    After updating and installing
    Done with restart
    After restart press we have to power on tv????
    Or automatically on??
    #70
  10. prasanthsiddarth
    Donut Oct 26, 2019
    prasanthsiddarth , Oct 26, 2019 :
    once after the update is completed , After the first boot i observed all the applications are damn slow and if i play any video from YouTube or prime it's getting stuck for couple of sec
    #71
  11. vicky3572
    Eclair Oct 26, 2019
    Yes same experience
    #72
  12. vicky3572
    Eclair Oct 26, 2019
    #73
  13. Sasi4395
    Cupcake Oct 26, 2019
    Sasi4395 , via OnePlus Community App , Oct 26, 2019 :
    have you faced backlight bleed issue like this test and try it?
    #74
  14. Subashdobby
    #75
    Venky61 likes this.
  15. sharadksingh
    #76
  16. vicky3572
    Eclair Oct 26, 2019
    What about Netflix support update in oneplus tv,customer care people said firstupdate will come with Netflix ??
    #77
    O1571949737897 likes this.
  17. prasanthsiddarth
    Donut Oct 26, 2019
    Even after update i see some stability issues while playing youtube 4k videos , sometimes video is getting stuck. Is anyone seeing the same problem
    #78
  18. RGVEDA
    RGVEDA , Oct 26, 2019 :
    What the hell? Are you even reading my posts that i write you? Why are you so impatient? Just buy another TV or use a Amazon Fire TV Stick or something else....
    #79
  19. Subashdobby
    that's because your wifi speed is not enough, i had same issues, after upgrading my network to 50 Mbps up/down it works fine. please try upgrading your network. what is your network & speed?
    #80
    Venky61 likes this.
