Dear suveerupadhyay:
After over 100 test about this issue, I locate that it is due to poor connection of the DDC channel of the HDMI cable provided by Xstream.
So, try replacing the HDMI cable provided by Xstream. and see if that helps.
How do i locate it?
I restart Xstream over 70 times at 20191230, flowing the path:Settings->Android Settings->Device Preferences->About->Restart.
At the first 40 times, i connect TV and Xstream using the HDMI cable provided by Xstream, it happens 4 times, it shows wrong timing(34*4319) at first, and then go black screen.
And then i replace the HDMI cable and repeat doing Restart over 30 times, it is normal after each try.
I test it again at 20191231.
I use the HDMI cable provided by Xstream again, and it happens twice within 6 times.
And then i replace the HDMI cable, do Restart over 30 times, it works fine after each try.
About:
Device name: XStream_Smart_Box_001
Model: XStream_Smart_Box_001
Version: 9
Android security patch level: 5 September 2019
Kernel version 4.9.159-1-6pre #2 Fri Nov 8 18:34:39 IST 2019
Release: hsw4026atl-1.0.9-191110817
Build: PTT1.190228.001.1.0.9-191110817
- File size:
- 86.3 KB
- 0
