16
System Update for OnePlus TV Y Series[OTA3]
  1. karthikoneplusx
    Cupcake Feb 15, 2021
  2. rwt.ajay
    Donut Feb 17, 2021
    rwt.ajay , Feb 17, 2021 :
    Hi I've exact same issue, let me know if you found a solution. I've started to get these within 3 months of purchase.
    #82
  3. karthikoneplusx
    Cupcake Feb 17, 2021
    karthikoneplusx , via OnePlus 3T , Feb 17, 2021 :
    I have connected Home theater through HDMI ARC port. Audio has not come default. But i have on and off at HDMI input mode at TV. Same audio is coming only MSTAR mode. Kindly Suggest MSTAR Mode defaultly.....
    #83
  4. gvamsi_krishna
    Gingerbread Feb 17, 2021
    #84
  5. Venky61
    OnePlus TV Expert Community Expert Feb 18, 2021
    Venky61 , Feb 18, 2021 :
    You can upload the video to Gdrive/Gphotos and share the link. As I understand the Connect App is crashing when you access the screen and data statistics right?
    #85
    Yash Pratap Singh. likes this.
  6. Kruzer
    Gingerbread Feb 18, 2021
    Kruzer , via OnePlus 7 , Feb 18, 2021 :
    Where I can check screen time and data statics in my tv 43y1
    #86
  7. Yash Pratap Singh.
    Lollipop Feb 18, 2021
    Yash Pratap Singh. , via OnePlus 7T , Feb 18, 2021 :
    Open OnePlus connect app, click on the top right icon which shows TV connectivity status and then click on 'Connected' below the TV logo. A new menu will open with required functions
    #87
  8. gvamsi_krishna
    Gingerbread Feb 19, 2021
    gvamsi_krishna , via OnePlus 6 Silk White , Feb 19, 2021 :
    Using 'Connect' app, after connecting your TV, click on the connected option then you'll get the menu for both.
    #88
    Venky61 likes this.
  9. RAM GOSAVI
    Cupcake Feb 19, 2021
    RAM GOSAVI , Feb 19, 2021 :
    I received Update on My Y series (32 Inch) TV,But after updates few issues arrives like TV started frequently on auto even if its on OFF position from remote.Please look into this & resolved.
    #89
  10. gvamsi_krishna
    Gingerbread Feb 20, 2021
    gvamsi_krishna , via OnePlus 6 Silk White , Feb 20, 2021 :
    Yes you are right. Here's the link: https://drive.google.com/file/d/168t4aI0mqCM_9KN-RNQkQp43E0I0bPLe/view?usp=drivesdk
    Also after this update, TV is not turning on with just a press of power button. Has to off the main power and switch on again. This problem was not there before, happening frequently everyday.
    #90
    Venky61 likes this.
  11. PratikGadani , via OnePlus Community App , Feb 20, 2021 :
    Instead of switching off and on try switching it on with the physical button behind the TV.
    I usually keep the power button pressed on remote till i see the small led goes off
    #91
  12. gvamsi_krishna
    Gingerbread Feb 21, 2021
    gvamsi_krishna , via OnePlus 6 Silk White , Feb 21, 2021 :
    I too usually do power button pressed on remote till i see the small led goes off but that is also not working now. Only way is to switch power off & on again to turn on TV.
    #92
  13. Venky61
    OnePlus TV Expert Community Expert Feb 22, 2021
    #93
  14. gvamsi_krishna
    Gingerbread Feb 22, 2021
    #94
  15. karthikoneplusx
    Cupcake Feb 27, 2021
    karthikoneplusx , via OnePlus 3T , Feb 27, 2021 :
    Hello.... Sound system could not connect during Tuner mode.... I have on and Off HDMI control at TV then MSTAR Mode change from Tuner... Kindly suggest procedure MSTAR Mode default.... Please find photo for reference...
    #95
  16. gautyagi
    Eclair Mar 8, 2021
    #96
  17. Yash Pratap Singh.
    Lollipop Mar 8, 2021
    #97
  18. Venky61
    OnePlus TV Expert Community Expert Mar 9, 2021
    Venky61 , Mar 9, 2021 :
    Hey,
    Do you have any HDMI device connected that has CEC feature?
    #98
  19. gautyagi
    Eclair Mar 10, 2021
    #99
  20. Anubhav9r
    Cupcake Mar 19, 2021
    Anubhav9r , via OnePlus 7 Pro , Mar 19, 2021 :
    Hello I am trying to connect my OnePlus series y 32 inch tv to my laptop by the image quality when I connect it to my laptop is very bad I can't understand the reason I tried updating the drivers and messing with the colour settings but it's not working. Do I have to enable pc mode for that ? I found it in settings but I can't enable
