16
System Update for OnePlus TV Y Series[OTA3]
  1. Venky61
    OnePlus TV Expert Community Expert Mar 20, 2021
    Venky61 , Mar 20, 2021 :
    Hey, what the resolution set in the laptop? Could you share a screenshot of the same.
  2. Anubhav9r
    Cupcake Mar 21, 2021
    Anubhav9r , via OnePlus 7 Pro , Mar 21, 2021 :
    It's 1920x1080 only but the problem is that when I acces a game the TV's resolution shifts to 1366x768 for some reason and making it worse all together.
  3. Venky61
    OnePlus TV Expert Community Expert Mar 21, 2021
    Venky61 , Mar 21, 2021 :
    And when the resolution changes when you start a game, are you able to change resolution from game's settings to 1080p?
  4. Yash Pratap Singh.
    Lollipop Mar 21, 2021
    Yash Pratap Singh. , Mar 21, 2021 :
    TV doesn't change its resolution, it reproduces the resolution of the laptop.
    Check the Video settings in your game and check which resolution your game is running. Many times people using a laptop lower game's resolution for better FPS or graphics
  5. Anubhav9r
    Yes I can change the in-game resolution but it just zoom in and the TV's resolution stays 1360x768
  6. Anubhav9r
    In first photo I put the resolution to 1920x1080
    As u can see it's showing 1920x1080
    When I open the game it switch back to 1360x768
    When I change it ingame it just zooms it
  7. Yash Pratap Singh.
    Hey
    The OnePlus TV 32Y1 is HD-Ready, not Full-HD
    Its maximum resolution is 1366X768 not 1920X1080
    So your maximum playable resolution will be what is shown in your PC i.e 1366X768 because that's what your 32Y1 TV supports
    (source - https://www.oneplus.in/tv-y-series)
    If you want HD resolution you'll have to buy the 43Y1 with 1920X1080 resolution.
    Thanks!
    Hope this helps
    Venky61 likes this.
  8. Venky61
    OnePlus TV Expert Community Expert Apr 11, 2021
  9. gautyagi
    Eclair Apr 12, 2021
  10. Yash Pratap Singh.
    Lollipop Apr 12, 2021
    Yash Pratap Singh. , Apr 12, 2021 :
    How much lag are you experiencing (in seconds)?
    Make sure to use a router for casting
  11. gvamsi_krishna
    Gingerbread Apr 12, 2021
    gvamsi_krishna , via OnePlus 6 Silk White , Apr 12, 2021 :
    I usually always keep connected my hard disk to my 43Y1 TV, down usb port. There are no issues before, but from few days TV stopped to recognise it. So obviously I can't see & use the content from it.
    Do anyone knows what can be the issue or any troubleshooting process to rectify this issue?
    @Venky61 Any inputs here please?
  12. Yash Pratap Singh.
    Yash Pratap Singh. , via OnePlus 7T , Apr 12, 2021 :
    Reconnect it?
  13. Venky61
    OnePlus TV Expert Community Expert Apr 13, 2021
    Venky61 , Apr 13, 2021 :
    First of all, connect it to another device and see if it's working or not. If it does then follow next,
    Check if it's atleast getting power with the TV, most of them have an Led on it. If there's no power, change the port and check again.
    gvamsi_krishna likes this.
  14. gvamsi_krishna
    Gingerbread Apr 13, 2021
    gvamsi_krishna , via OnePlus 6 Silk White , Apr 13, 2021 :
    Yes, able to connect & use it with laptop.
    And it's getting power, LED is blinking.
    Yash Pratap Singh. likes this.
  15. Venky61
    Ok. Try checking with some other file manager like x-plore or solid explorer.
  16. gautyagi
    Eclair Apr 13, 2021
    gautyagi , via OnePlus 6 , Apr 13, 2021 :
    Around 5 to 8 second or might be more , depending on the app's or web sities
  17. gvamsi_krishna
    Gingerbread Apr 14, 2021
    gvamsi_krishna , Apr 14, 2021 :
    After connecting hard disk to TV, LED is blinking and then I checked under Settings --> Device Preferences --> Storage, here only 'Internal shared storage' only visible. Previously hard disk storage is visible here.
    So then I checked with Solid file explorer and not able to see storage there also.
    After all these checks only, I didn't understand what happened and thought to check here in forums for any ideas.
  18. AvdhutAtkale97
    Froyo Apr 14, 2021
    AvdhutAtkale97 , via OnePlus 6 , Apr 14, 2021 :
    Didn't knew ignoring the customers was also in the bag of OnePlus support 😏. I have done all sorts of advices provided to me and still haven't received the solution. Should I give up on updating my TV?...@venky
  19. Venky61
    OnePlus TV Expert Community Expert Apr 14, 2021
    Venky61 , Apr 14, 2021 :
    Ohhh... That's strange. Check if the TV is detecting any other pendrive or hdd if you have. If not I think, resetting the TV would be a quick but tiduous way to solve this.
    Hey, screencasting is indeed slow sometimes. I did face it too. And more than the OTA update, it has to do with the update we get with Chromecast built-in app. Google really messes up many times. Try uninstalling updates for that app and re-update the app and check if it helps.
  20. AvdhutAtkale97
    Froyo Apr 14, 2021
    Bro are you even listening what I'm saying? I didn't got single OTA update to my TV that's what I'm asking and here you are giving me the info I don't give shit about.
