25
System update for the OnePlus TV [OTA5]
  1. #21
    Venky61 likes this.
  2. sharadksingh
    Honeycomb Jul 3, 2020
    sharadksingh , via OnePlus 5T , Jul 3, 2020 :
    It's under wifi network.
    Venky61 likes this.
  3. #23
    Venky61 likes this.
  4. Brahmania
    Donut Jul 4, 2020
    Brahmania , via OnePlus 6 , Jul 4, 2020 :
    Plz go to Network and Internet option and you will find the data saver plus option there
    Venky61 likes this.
  5. #25
  6. prasad299
    Cupcake Jul 4, 2020
    prasad299 , Jul 4, 2020 :
    I hv applied the update to my Q1 pro and after few hours display got turned off while watching the movie but the audio is running.. not sure if the issue is with update or something else
  7. Venky61
    OnePlus TV Expert Community Expert Jul 4, 2020
    Venky61 , Jul 4, 2020 :
    Hi.. Once you pair the BWZ, you can use the multipoint feature of BWZ where you can just connect by detaching the magnets and double-tapping the power button to switch from phone connection to TV. I generally do that, so no need to go into settings every time. Hope this helps.
    It's 60 Hz
    Did the display turn ON after a while or still off?
    Praneeth_Shetty likes this.
  8. prasad299
    Cupcake Jul 4, 2020
    Still same issue.. tried to restart multiple times
  9. prasad299
    Cupcake Jul 4, 2020
  10. Brahmania
    Donut Jul 4, 2020
  11. Venky61
    Stickied Post
    Hey Guys,
    So the OTA5 for the OnePlus TV Q series has brought so many new features and changes to the interface that was not mentioned in the changelog. I listed them out here for you to easily check them :)
    • Data Saver Plus feature added in Settings < Network & Internet. Helpful to monitor data, control bandwidth and have alerts for data usage.
    • Modified Audio Output Settings Page - Now you have more options to select as per the sound output you are using.
    • 2 New Added picture modes
      - AI PQ mode automatically adjusts the picture setting, so except for Backlight control, everything else is Auto controlled.
      - Eyes Protection Mode - Has a low Backlight value set with some tuning done by the team w.r.t gamma, sharpness and color for a lesser strain on the eyes.
    • Modified Log/Feedback Section - The log upload is now renamed as "Bug Report" and you can find this at Settings<More Settings<Bug Report. It has options to select the reason for uploading log and gives the device info.
    • Improved Oxygen Play Experience
      - More content partners added and now you can long-press any image for reading some info about the title before watching it.
      - Modified Watch History interface.
      - Removed App drawer for a more media-centric experience.
      - Upcoming tab added for setting reminders for to be released content.
    • Kids Mode - A separate profile can be created for kids with a selection of Apps to be displayed, timer and security pin.
    • Prime Video App now stays in memory when you click home.
    • TV Shared Album - If you have OnePlus 7/7pro, you can sync your photos and videos to cloud and view them directly on TV.
    • IOS Connect App Support.
    • Improved Video Player
      - While playing any video in the Default Video Player, clicking down button will show the other videos in the folder as a playlist.
      - The videos resume from previous time stamp and if you want to play from the beginning, click OK.
      - The Subtitles selection now shows language of the subs available.
      - Improved performance in the playback of mkv and mp4 HDR files.
    • Format Storage option is back. Now you can expand the storage with external USB/HDD.
  12. Venky61
    Ok. Keep it turned OFF with power connection removed for at least half an hour and try again. Is it at least giving the power menu?
    Hi,
    If you are getting an option to update the Sony Liv App on Play store, then update. If that doesn't work, go to Playstore<Search and scroll through the popular apps listed below the search bar. You will find the Sony Liv App with new logo. Install it and use.
  13. Brahmania
    Donut Jul 4, 2020
    Thanks Venky...
    Venky61 likes this.
  14. prasad299
    Cupcake Jul 4, 2020
  15. Venky61
    Please try this and if this doesn't work, wait for the technician. If you get this page, reset and see if it helps.
  16. #36
  17. Venky61
    I know... It might take more time. The team's looking into it.
  18. kichavas
    Eclair Jul 4, 2020
    kichavas , Jul 4, 2020 :
    What do you mean by unlocked accessibility settings??
    #38
  19. Venky61
    Couple of 3rd party apps (tools) like remote button mapper need permission for Accessibility Service and that's not possible right now.
    #39
    kichavas likes this.
  20. P1508773651969 , via OnePlus 7 Pro , Jul 4, 2020 :
    You can use Google assistant while using the app and say "settings" or "open settings" in this way you don't have to close the app you can use setting while app is open
    #40
    Venky61 and Shub#9 like this.
