System updates via OnePlus 9R
  1. X1630161158655
    Cupcake Dec 3, 2021
  2. Caomhin
    9 Series Expert, Participator of the Year Community Expert Dec 3, 2021
  3. Tokolozi
    The Lab Reviewer - OPPO Find N Dec 3, 2021
    Tokolozi , Dec 3, 2021 :
    *NSA liked this*
  4. X1630161158655
    Cupcake Dec 3, 2021
  5. Sheppards
    Jelly Bean Dec 3, 2021
  6. Caomhin
    Caomhin , via OnePlus 9 Pro , Dec 3, 2021 :
    Are you using the default Google Dialler that came with the phone or a sideloaded OnePlus Dialler which can have these issues ?
  7. X1630161158655
    Cupcake Dec 3, 2021
    X1630161158655 , via OnePlus 9R , Dec 3, 2021 :
    The dailer that came with phone, all settings are to the default
  8. X1630161158655
    Cupcake Dec 3, 2021
  9. Caomhin
    Check on the Playstore to see if there is an update for the Google Phone. If not, you may have to reset the phone app by clearing both App info Cache and App info Storage as well. To see if that will rectify it. It will clear all saved recent calls, but if you have Google backup to backup recent calls enabled it may restore them.
  10. Aaron2017
    General Support Expert Award 2021 Dec 3, 2021
    Aaron2017 , Dec 3, 2021 :
    In the recent section click on the contact name, not the profile next to it, the name itself, and select history. You should see all calls you've had/made with that contact. I can go all the way back to 2019 for some contacts that way
  11. Swejuggalo
    OnePlus 9 Series Expert Community Expert Dec 3, 2021
    Caomhin likes this.
