Network/Connectivity T-mo OP7Pro - No 4G After Disconnecting Wifi (Oxygen OS 10)
  1. nblackstock01
    Cupcake Jan 14, 2020 at 4:30 PM
    nblackstock01 , Jan 14, 2020 at 4:30 PM :
    Hey OnePlus community... this issue started for me on my T-Mo OP7Pro after receiving the Oxygen OS 10 update.
    I've noticed that after being connected to wifi for a while, whether my home network or elsewhere, upon disconnecting (either manually or when moving out of range) my 4G network speed doesn't automatically kick in. There does appear to be a network data connection, but I don't even get the 2G connection logo... just the regular "bars" indicating a connection of some kind. Obviously, speeds are terribly slow when this happens; to the point of there not seeming to be a connection at all.
    The only thing that I've come across thus far that allows for 4G to return is to reboot the phone. No turning on/off airplane, data, wifi etc works. Anybody else experienced this and/or know of a fix or is this a bug, needing the next update for the T-mo OP7Pro?
    Any and all help is much appreciated!
