29
T-Mobile 6T to Global model Conversion (WITHOUT unlocked bootloader/SIM unlock!)
  1. BlackKnight2332
    Honeycomb Jan 31, 2019
    BlackKnight2332 , Jan 31, 2019 :
    it's best to start fresh when experiencing issues. I know it's a pain but you're having issues, I would setup as a new device.
  2. brandonb4935
    Gingerbread Jan 31, 2019
    brandonb4935 , Jan 31, 2019 :
    Okay, I'll have to do it tomorrow when I'm off work since it took almost 6 hours of work to get everything updated and my backup restored.
  3. BlackKnight2332
    I did it exactly the way I told you and I haven't experienced these issues you mentioned.
  4. brandonb4935
    I messed up when I initially did the switch, I ended up using the wrong msm tool, my phone was bricked for about 2 hours. I actually called T-Mobile and had them order me a new phone. Then out of nowhere it started working again, so I redid the conversion using the correct msm tool and it worked, except for these issues with the apps. I did get the Play Store working I think by uninstalling it then reinstalling it. And I found an alternative to the TMO visual voicemail. I just have to find an alternative to nameid. Also I think my apps may be working, Footlocker loaded fine at least.
  5. BlackKnight2332
    the phone supports visual voicemail natively
    brandonb4935 likes this.
  6. brandonb4935
    BlackKnight2332
    yeah I found that out when I was adjusting how many times my phone rings until it goes to voicemail, but I downloaded a really nice app called instavoice, and it works awesome plus has some cool features. oh and I just checked my NBC app works fine, it seems like the conversion just needed time to settle, that's the only thing I can think of.
    BlackKnight2332 likes this.
  7. brandonb4935
    I'm gonna hold off on the redoing everything and use it for a day and see how things go. If I start experiencing problems again I'll do what you said. thanks for the help.
  8. Nate358
    Froyo Feb 1, 2019
    Nate358 , Feb 1, 2019 :
    My T-mobile visual Voicemail app isn't working either.
  9. Nate358
    Froyo Feb 1, 2019
    I must say that the battery life is so much better after doing this! Before the latest Tmobile update I was getting 9 hours screen on time... Then it went down to 7 hours SOT after 9.0.3 update. I just did my first full day and am at 10:15 of SOT! Wow!
  10. Nate358
    Froyo Feb 1, 2019
    I do miss Google home app on my home screen swipe right. Is there any way to get that back instead of the shelf?
  11. brandonb4935
    Gingerbread Feb 1, 2019
    brandonb4935 , Feb 1, 2019 :
    you can try this but you have to have root, I don't know if it will work because as far as I've seen the TMO version is the only one that has it, but I actually changed mine to the OnePlus shelf when I got my 6T, here's the link https://www.teamandroid.com/2018/10/07/install-google-now-feed-oneplus-phones/
    again you need to have root and IDK if it will work.
  12. MrB1000
    Gingerbread Feb 6, 2019
    MrB1000 , Feb 6, 2019 :
    the conversion to international does work have little problems with it to figure out how to connect it to the computer as of pushing what buttons what time frame
  13. brandonb4935
    brandonb4935 , Feb 6, 2019 :
    hey just wanted to give you a update. I've been using it now for almost a week and everything is working fine. So it looks like I won't have to reinstall the OTA direct from OP. I guess the conversion just had to settle, because I'm not experiencing any of the problems I initially had the first day I converted it, everything seems to have smoothed out.
    BlackKnight2332 and ironass like this.
  14. BlackKnight2332
    Honeycomb Feb 6, 2019
    BlackKnight2332 , Feb 6, 2019 :
    that's good. I always try to clear cache and restart my phone before performing any updates
  15. G_WesoJR_vllT
    Eclair Feb 13, 2019
  16. narceoneplus2
    Ice Cream Sandwich Feb 13, 2019
    narceoneplus2 , Feb 13, 2019 :
    I think this is because the app is not yet optimized to recognize dual SIMs. That is simply my opinion.
  17. Drewbikscube
    The Lab - OnePlus 6T Reviewer Feb 13, 2019
    Drewbikscube , Feb 13, 2019 :
    I sold my last 6T I converted a few weeks ago, but I actually got another one outright from T-Mobile today for free basically with account credits I was issued. I ran the conversion again right out of the box, worked immediately. Following the conversion, I received the OTA update for 9.0.12 so this definitely works! Confirmed, OTA updates received following the conversion out of the box! This is incredible for those with the T-Mobile version looking for the latest updates!
    Conversion running on new T-Mobile 6T:
    Software Update installing :
    Latest 9.0.12 OTA Installed:
  18. MrB1000
    Gingerbread Feb 13, 2019
  19. Nate358
    Froyo Feb 16, 2019
    Nate358 , Feb 16, 2019 :
    I am also not seeing the new OTA update even after using a VPN to Germany and Canada. I came here to see if anyone else is getting their converted 6T to update OTA.
  20. MrB1000
    Gingerbread Feb 16, 2019
    MrB1000 , Feb 16, 2019 :
    which folder do I put the download of OTA zip for local upgrade I haven't had no luck of finding where to put it.
