24
T-Mobile 6T to Global model Conversion (WITHOUT unlocked bootloader/SIM unlock!)
  1. Urbanowskic Cupcake May 14, 2019
    Urbanowskic, May 14, 2019 :
    Do I get the files on his website or xda
  2. Chumdini Gingerbread May 14, 2019
    Chumdini, May 14, 2019 :
    I would go to xda personally . what will happen is u will flash to 9.0.11 then u will should get some ota updates after completion.
  3. Urbanowskic Cupcake May 14, 2019
    how many files do I download those 4?
  4. Chumdini Gingerbread May 14, 2019
    Urbanowskic
    how many files do I download those 4?​
    yes . u download everything it says too and make sure to save them in the same folder.
    edit. u extract the files to the same folder.
  5. Urbanowskic Cupcake May 14, 2019
    so I need a zip folder or anything to download
  6. Chumdini Gingerbread May 14, 2019
    yeah u will need something to unzip the files.
  7. Urbanowskic Cupcake May 14, 2019
    what did you use and do I download the files in the unzip one
  8. Chumdini Gingerbread May 14, 2019
    I believe I did mine WinZip . unzip/extract everything u can into the same folder should end up being like 4 files it I remember correctly .
  9. Chumdini Gingerbread May 14, 2019
    u can put everything in the same folder to be safe. that's what I did . I created a folder dropped the zipped files then extracted to the same location.
  10. Urbanowskic Cupcake May 14, 2019
    WinZip free right
  11. Chumdini Gingerbread May 14, 2019
    yes for like 30 days . then I just delete and reinstall when need to
  12. Urbanowskic Cupcake May 14, 2019
    I'm gonna try it hopefully nothing happens to my phone
  13. Chumdini Gingerbread May 14, 2019
    Urbanowskic
    I'm gonna try it hopefully nothing happens to my phone​
    read through the instructions a.few times and u should be fine.
    see you on the otherside
  14. Urbanowskic Cupcake May 14, 2019
    do I need to buy now or reevaluating one
  15. Chumdini Gingerbread May 14, 2019
    just do the evaluation one
  16. Urbanowskic Cupcake May 14, 2019
  17. Chumdini Gingerbread May 14, 2019
  18. Urbanowskic Cupcake May 14, 2019
  19. Chumdini Gingerbread May 14, 2019
    download the files from those two links.
  20. Urbanowskic Cupcake May 14, 2019
    I didn't I pop up a weird name
