31
T-Mobile 6T to Global model Conversion (WITHOUT unlocked bootloader/SIM unlock!)
  1. TypewriterChaos
    Eclair Jan 6, 2020
  2. gusmuh
    Cupcake Jan 8, 2020
    gusmuh , Jan 8, 2020 :
    I'm on an unlocked T-mobile 6t converted to international. If I just wait for the non-beta OTA for 10 to hit my phone, should it update OTA with no problems? Am I still dependent on T-moblie for the timing of the update? Thanks!
  3. Chumdini
    Honeycomb Jan 9, 2020
    Chumdini , via OnePlus 6T , Jan 9, 2020 :
    the whole point of converting to international variant is so that you will not be locked to T-Mobiles update schedule. if you have successfully converted, you can use oxygen updater, the download from oneplus.com if you don't want to wait for the ota.
    ironass and gusmuh like this.
  4. gusmuh
    Cupcake Jan 13, 2020
    gusmuh , via OnePlus 6T , Jan 13, 2020 :
    Thank you Chumdini. You gave me the confidence to update with Oxygen Updater and it went smoothly. There was an incremental update, then to 10.3.0. The only issue is that I get a message that I can't use Google Pay because my device's software doesn't meet software standards.
    Anyone - What's the fix for this? I appreciate the convenience of Google Pay when I am out and about.
  5. Chumdini
    Honeycomb Jan 13, 2020
    Chumdini , via OnePlus Community App , Jan 13, 2020 :
    it's because safety net fails. to my knowledge there hasn't been a fix unless you root the device. I have sent logs to OnePlus in hopes for a fix.
    gusmuh likes this.
  6. ironass
    Lollipop Jan 14, 2020
    ironass , Jan 14, 2020 :
    If you have converted your T-Mobile (USA) model to the global version, as per post #1 of this thread, and have joined the Open Beta test firmware programme... then this should be coming to you soon, either OTA or via Oxygen Updater...
    OnePlus have just started the Open Beta 4 roll out for Android 10 OTA for the OnePlus 6 & 6T, (strangely enough, referred to as Open Beta #29 & #18 respectively, in the OnePlus Downloads & Update store), to test new features and fixes that may or may not, come to future firmware updates. You will only receive this test firmware OTA if you are already on their Open Beta releases.
    Changelog
    System
    •Optimized details for Emergency Rescue
    •Added a feature to support reminders for privacy alerts
    •Improved system stability and fixed general bugs
    •Updated Android security patch to 2019.12
    Phone
    •Added ringtone increasing and decreasing features for incoming calls
    Reading Mode
    •Fresh new chromatic effect for a more immersive and comfortable reading experience with smart color gamut and saturation adjustment (Settings-Display-Reading Mode-Turn on Reading Mode-Chromatic effect)
    Android Security patch = December 2019
    Camera version = 3.8.96
    This is the 21st Open Beta release for the 6T in 366 days = 1 update, on average, every 17 days.
    (N.B. Open Beta is NOT available for the T-Mobile (USA) carrier minority variant firmware)
    Chumdini likes this.
  7. ironass
    Lollipop Jan 22, 2020
    ironass , Jan 22, 2020 :
    If you have converted your T-Mobile (USA) model to the global version, as per post #1 of this thread then this should be coming to you soon, either OTA or via Oxygen Updater...
    OnePlus has begun the OTA, (Over The Air), rollout of their new stable Android 10 OxygenOS firmware, 10.3.1, for OnePlus 6T, McLaren and OnePlus 6 users.
    This is the 7th Android 10 stock/beta release in 3 months.
    As always, there will be a limited roll out initially, followed by the global roll out in a few days.
    Build date = 15 January 2020
    Changelog
    System
    • Fixed the issue with a black screen appearing after unlocking device using fingerprint
    • Fixed the issue with the animation logo while rebooting device
    • Fixed the issue with the device heating up while charging
    • Fixed the random disconnection issue with 5Ghz hotspot
    • Improved system stability and fixed general bugs
    • Updated Android security patch to 2019.12
    Camera
    • Optimised the image preview time in the Pro mode
    • Fixed the camera crash issue
    Gallery
    • Fixed the issue with video and images not displaying in Gallery
    Android security patch = December 2019
    Camera version = 3.8.96 (TBC)
    This is the 16th official, stable, update for the 6T in 440 days. 1 update on average, every 28 days
    (N.B. OxygenOS 10.3.0 is not available for the T-Mobile (USA) carrier minority variant)
  8. N1581888893849
    Eclair Feb 16, 2020
    N1581888893849 , Feb 16, 2020 :
    Ight i don't know if anyone is still reading this thread but Oneplus is selling a Tmobile 6t for $200 off. Im thinking about getting it but does this convert still work as i don't have tmobile I have ting and i want to be able to convert this right away and use it with Ting right away. Do we know if it's still possible?
  9. N1581888893849
    Eclair Mar 15, 2020
    N1581888893849 , via OnePlus 6T , Mar 15, 2020 :
    so I switched over to international...which is awesome ...my phone doesn't heat up anymore and batter life is better. The issue I have is that gpay no longer works, Netflix can't be added because my phone doesn't pass safteynet. Do you know if there is a workaround that is not rooting the phone as I'm afraid that I will mess it up and brick my phone. I have zero experience rooting a phone
  10. kjjm
    Gingerbread Mar 15, 2020
    kjjm , Mar 15, 2020 :
    No. At the moment the only way to get play certification on a T-Mobile 6T running A10 is to use T-Mobile's A10 update.
  11. N1581888893849
    Eclair Mar 15, 2020
    so I would have to revert back to the T-Mobile version??
  12. kjjm
    Yes - MSM back to the T-mo A9 firmware (look on xda for that) and then take the OTA's to the current version. Your data will be wiped, so back-up.
  13. N1581888893849
    Eclair Mar 15, 2020
  14. kjjm
  15. N1581888893849
    Eclair Mar 15, 2020
    yeah I might jus roll with how it is now. Just sucks not working to it's full capacity. But the better battery life and cooler phone not to mention faster. if I wanna watch Netflix I guess I'll watch it on my TV lol.
  16. G1563387679066
    Cupcake Mar 31, 2020
  17. Nodnarb
    Cupcake Apr 5, 2020
    Nodnarb , Apr 5, 2020 :
    I am receiving a warranty replacement 6T form TMO Monday:
    Several questions:
    A. will the instructions in post 1 of this thread still work as written?
    B. what , if any Drawbacks. other than the gpay/netflix issues should i expect( i dont use either of those on this device)
    C. are there any OTHER versions i can flash to...like the stock oneplus version that come on units purchased/shipped in the USA from OP?
  18. Alex1681
    Gingerbread Apr 16, 2020
    Alex1681 , Apr 16, 2020 :
    How to do this for OnePlus 7T T mobile to international
  19. Manan79
    Cupcake Apr 21, 2020
    Manan79 , Apr 21, 2020 :
    with my 6t t-Mobile converted to international variant , I can flash ROMs but the fingerprint sensor doesn't work 80% of times..in aosp ROMs I tried many different ROMs, same issue ...is it because TMobile phone running international firmware? should I try official day to unlock TMobile after installing the stock TMobile firmware ...will it make difference to fingerprint issue
