t-mobile visual voicemail work around that worked for me.
  1. xyu takou Cupcake Jul 16, 2019
    xyu takou, Jul 16, 2019 :
    Here is what worked for me, im on t-mobile with unlocked versions i suggest that you download "My Visual Voicemail" by "Virtual Network Apps" in the play store. So install the app and disable wifi before opening,, then accept all permisions once its finished,,,,, then go into app settings click disable visual voicemail. Then uninstall the app. Restart phone.. if dialer missing vvm tab go into the oneplus dialer and chose settings, then click call settings, then click voicemail, then you should see a visual voicemail toggle. Switch that on. It should work. it worked for me like a charm
  2. pltansupermanac Donut Aug 1, 2019
    pltansupermanac, Aug 1, 2019 :
    can't disable the visual voicemail app. only uninstall. can't find a native visual voicemail to disable
