T-Mobile WiFi Calling No longer Works
  1. tanner.j.michels
    Gingerbread Jan 19, 2018
    tanner.j.michels , Jan 19, 2018 :
    The Wifi Calling feature no longer works after the newest update on my 3T 5.0.1. I rely on the feature at work. My office in the basement and I do not have reception. TMobile told me that everything on their end if perfect and everything is enabled. They said that it must be the device. It worked perfectly fine before the Update.Please fix it! I may be.the new WiFi hotspot manager that was added.
  2. G_Julio_Mendoza_SLaf
    Ice Cream Sandwich Jan 19, 2018
  3. tanner.j.michels
    How did you get to work? Because it most certainly does not on my device. I haven't done anything special to it.
  4. G_Julio_Mendoza_SLaf
    G_Julio_Mendoza_SLaf , Jan 19, 2018 :
    I haven't done anything to it. Sometimes it takes a few seconds to pick it up.
    Make sure your e911 on T-Mobile is setup correctly. Try also resetting the APN.
    Hydra Bob and tanner.j.michels like this.
  5. Deactivated User
    Jan 19, 2018
  6. tanner.j.michels
    thanks!
  7. tanner.j.michels
    Deactivated User likes this.
  8. tanner.j.michels
    I called T-Mobile and they said that everything is fine on their end my e911 is registered properly they reset my network settings I turned my phone on and off. so I even called the my University IT people to check if they did a security patch that blocks wifi calling and they said no. both the IT people as well as the T-Mobile people all said it's something's wrong with the phone or the software update. so what do I do everyone?
  9. Deactivated User
    Jan 19, 2018
    Hydra Bob likes this.
  10. tanner.j.michels
    no I'm not getting the VoWIFI.
  11. Deactivated User
    Jan 19, 2018
  12. tanner.j.michels
    I'm basic. I just have whatever OnePlus gives me
  13. G_Julio_Mendoza_SLaf
