Working tap to wake up always vibrate (A10) op6t
  1. I1573533760066
    Cupcake Nov 23, 2019
    I1573533760066 , Nov 23, 2019 :
    my phone has update to Android 10, and after I play around at vibration setting, the double tap to wake, always vibrate. does anyone knows how to fix this annoying vibrate?
    fasals likes this.
  2. Baymax
    Starting Point Expert Community Expert Nov 24, 2019
    Baymax , Nov 24, 2019 :
    settings- sound and vibration - and then turn off vibrate on tap
  3. I1573533760066
    Cupcake Nov 24, 2019
    I1573533760066 , Nov 24, 2019 :
    As my thread says, I have Android 10, I have read the older post regarding this issue. it seems for older version the problem has fixed. mine however doesn't work even I uncheck the touch vibration (haptick feedback)
  4. Baymax
    Hmm. It appears to work for me...
    Can you try turning touch vibration off and restarting your phone?
  5. fasals
    Cupcake Dec 15, 2019
    fasals , via OnePlus 7 Mirror Gray , Dec 15, 2019 :
    Same here, I'm using OP7 with A10 Oxygen 10.0.3 in Android Pie the problem had been fixed but now it seem came back.
    The previous solution was Settings/System/Accessibility/Intensity of tactile response and vibration and select all disable, but now this solution doesn't work.
