Hey everyone,
We know everyone is excited to finally try the delicious Pie update on the OnePlus 3 and OnePlus 3T. Thanks to the feedback from our beta testers, we are getting closer to launching Android Pie on the OnePlus 3 and 3T.
Now, we would like to invite you to download and try the Community Build available here and continue to help us shaping the stable update. Anyone can try this build, but please have in mind it won’t be available via OTA, you’ll have to download and install it yourself.
Download Community Beta for OnePlus 3
Download Community Beta for onePlus 3T
Those who download the Community Beta build will get OTA update when the stable build is released.
we look forward to hearing your continued feedback in the bug reporting forum here: https://forums.oneplus.com/feedback/.
Changelog
- System
- Updated system to Android™ 9 Pie™
- Brand new UI for Android Pie
- Updated Android security patch to 2019.4
- Do Not Disturb mode
- New Do Not Disturb mode with adjustable settings
- New Gaming mode 3.0
- Added text notification mode
- Added notification for 3rd party calls
- Phone
- Deep integration with Google Duo
- Camera
- Integrated Google Lens mode
Instructions for updating to the Community Build
For those on the latest stable version
181206
Preconditions: Boot Loader should be locked
Steps:
- Download the file from the link provided on the forum post
- Move the downloaded file to internal storage root folder using the File Manager.
The device can then be updated via two methods.
- First method: Local Update
- Open Settings -> System update -> Click top right setting icon
- Choose Local update
- Click on the downloaded file and wait until the device reboots
- Second Method: Recovery Update
- Turn off the device -> Press power and volume up key simultaneously until the device enters the Fastboot Mode
- Navigate to Recovery option using volume and power button -> Choose English -> Install from Internal storage -> Select the downloaded zip file -> Select 'Yes'
- Wait until the installation is complete -> Reboot
For those who are on the latest Open Beta version
180712
Note: The entire data will be wiped since there will be a version transition from Open beta to the stable version. If you made a OnePlus Switch backup, be sure to make a copy of it before moving forward.
Steps:
- Download the file form the link provided on the forum post
- Device can be updated only via Recovery Update:
Thank you once again for all your patience and we can’t wait to get your feedback.
We are one step closer to releasing the Pie for OnePlus 3 / 3T, you can now download and try our community build right now.
Never Settle.
