tempered glass screen is very fragile
  1. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Jul 10, 2018
    NeVeR_SeTTLe , Jul 10, 2018 :
    Full of scratches? I have no idea what you are doing with your phone that within a day you got so many scratches?? :p
  2. avraham67
    Cupcake Jul 10, 2018
    avraham67 , Jul 10, 2018 :
    I kept it in my pocket with keys and coins
  3. NeVeR_SeTTLe
    I always keep it in my pocket without the coins and keys.
  4. avraham67
    I never had a problem with other screen protector (on other phones)
  5. NeVeR_SeTTLe
    Remember, it's just glass.
    As I mentioned above, the tempered glass nowadays is thinner than other older tempered glasses due to the fact that the display of the device is more ratio to percent glass.
  6. avibored
    Honeycomb Jul 10, 2018
    avibored , Jul 10, 2018 :
    I didn't drop my phone I dropped my earphones on my phone and it cracked
  7. NeVeR_SeTTLe
    You dropped your earphones on the phone?
    What earphones do you have? Ones with titanium metal?
  8. avraham67
    did you talk to customer service
  9. NeVeR_SeTTLe
    @avraham67 @avibored I don't think OnePlus will refund you. As I see it, it was your fault (you dropped something on the phone and in the other case you put it in your pocket with keys and coins). If you are unhappy with the OnePlus 6 Tempered Glass, then buy a 3rd party one.
    GopalB. likes this.
  10. GopalB.
    Nougat Jul 10, 2018
    GopalB. , Jul 10, 2018 :
    Tight pockets may be!!!
    NeVeR_SeTTLe likes this.
  11. eye842
    Lollipop Jul 10, 2018
  12. NeVeR_SeTTLe
    A very good point indeed, Eye :)
    eye842 likes this.
  13. RJBoss
    The Showcase Reviewer Jul 10, 2018
    RJBoss , Jul 10, 2018 :
    I've been using the offical OnePlus 6 Tempered Screen Protector that I too purchased from the OnePlus Website and it's great. It's been 1 and a half months, and no sign of crack and fragility. Learn to use it properly, and you'll have no issues!
    NeVeR_SeTTLe and BeingIncog like this.
  14. kapil reddy karra
    kapil reddy karra , Jul 10, 2018 :
    I have used Samsung s series and note series, never had problem with tempered glass from spigen.
    Drewbikscube likes this.
  15. RJBoss
    Never tried Spigen's glass for my OnePlus devices.
  16. Drewbikscube
    The Lab - OnePlus 6T Reviewer Jul 10, 2018
    Drewbikscube , Jul 10, 2018 :
    I've heard the OnePlus screen protector isn't great. I was going to purchase one since the initial one it shipped with is even worse and scuffed up after just 4 days of minimal usage. (I'm in IT and the phone sits on a desk 90% of the day, never seen a screen protector get this bad before.) I ended up ordering some off Amazon. Some customer reviews said they didn't fit perfectly, but at least screen protectors are typically inexpensive so I figure I'll try it out and report back! I usually use this same brand on all mobile devices and they're usually all pretty good, so I have faith they'll work out OK. I'll receive and apply tomorrow.
  17. xnutzii
    xnutzii , Jul 10, 2018 :
    I had two screen protectors for the 5T, both of them cracked...But I didn't do anything really, one of them cracked while the phone was just laying next to me on the table, and the other one cracked during the night...lmao. Since then I haven't ever used a screen protector, because I don't know why, every single SP breaks on me.
  18. NeVeR_SeTTLe
    Really?
    #38
  19. xnutzii
    #39
  20. NeVeR_SeTTLe
    I think it's due to the tempered glass being thinner. I mean the OnePlus 3T / 5 screen protectors compared to the OnePlus 5T / 6 are way thinner.
    #40
    xnutzii likes this.
