7
Tempered Glass
  1. Esmeralda007
    Gingerbread Mar 5, 2017
    Esmeralda007 , Mar 5, 2017 :
    Noo... It's useless.. I have that
    #81
    Ranjithsmart likes this.
  2. G_Sid_Gog_gucx
    Honeycomb Mar 5, 2017
    G_Sid_Gog_gucx , Mar 5, 2017 :
    Haha! Then you my dear are a slow reader. Anyways I think you have made your mind to go with OP glass. IMHO nothing beats OEM screen protector and a protective case having raised edges.
    Good luck.
    #82
  3. NitinIndianTech
    Cupcake Mar 5, 2017
    NitinIndianTech , Mar 5, 2017 :
    use original company lunch tempered glass. i will tell why
    1. while watching video u will notice extras darkness
    2. while chatting on Twitter u will notice icons not visible neatly.
    3. response
    4. original behave very well but yes Price is very high as compared other 1500/- around.
    #83
  4. deveshmeena
    Cupcake Mar 17, 2017
    deveshmeena , Mar 17, 2017 :
    please dont by tempered glass from oneplus webside as it also shows bubble on screen and looks very bad total wastage of money.
    #84
  5. G_sasi_kumar_bWMW
    #85
  6. deveshmeena
    i purchage from oneplus site at amout of rs 1400 but it also shows bubble on screen
    #86
  7. sanjeetthokchom
    Cupcake Mar 18, 2017
    sanjeetthokchom , Mar 18, 2017 :
    just purchased the one plus 3t curved glass screen protector and tranlucent grey case from OnePlus.in store, the curved screen is covering some parts of the screen at the sides , also the translucent grey case is not compatible with the curved tempered Glass Screen Protector as once applied it pry opens the glass screen protector from the sides, typical case of hard earned money gone down the drain
    #87
  8. Bazilc
    Bazilc , Mar 18, 2017 :
    Hi i just received my screen saver from oneplus. The 3d curved one. Fits very good and is edge to edge and won't let dust behind it. I have tried alot of other makes and they all let dust in behind them and do not stay on for long
    Also bought a poetic revolution case from eBay and removed the built in screen saver. This gives total protection.
    #88
  9. jyotidevichandel
    Cupcake Mar 20, 2017
    #89
  10. shiva_gsp
    Donut Apr 8, 2017
    #90
  11. agoinfly
    Marshmallow Apr 8, 2017
    #91
  12. Sarath88
    Donut Apr 11, 2017
    Sarath88 , Apr 11, 2017 :
    Op3 tempered glass is fine but check the product while delivery it may have some flaws
    #92
  13. Arun0908
    Cupcake Apr 19, 2017
    Arun0908 , Apr 19, 2017 :
    bro can u suggest me a good tempered glass I am using the Spigen Rugged Armor case and my curved tempered glass popped out when I put the case so the tempered glass was useless.
    #93
  14. francescobrancatella
    Cupcake May 18, 2017
    #94
  15. G_hitesh_sirvi_yzSs
    Cupcake Jun 2, 2017
    #95
  16. Ranjithsmart
    Jelly Bean Jun 2, 2017
    Ranjithsmart , Jun 2, 2017 :
    After a long time do you face any problems with that glass like side opening etc,,.?
    #96
  17. Ranjithsmart
    Nice reply!!!!!!!
    #97
  18. Ranjithsmart
    Share it here
    #98
  19. F_Mohamed_Ahnaf_ZBKJ
    Cupcake Jun 2, 2017
    #99
  20. Wackencorpse
    KitKat Jun 2, 2017
    Wackencorpse , Jun 2, 2017 :
    No, but I am also using auf Cruzerlite Bugdroid TPU Cases. Both fit perfectly and everything is still ok...
