7
Tempered Glass
  1. Esmeralda007
    Gingerbread Jun 3, 2017
    Esmeralda007 , Jun 3, 2017 :
    I stock now!
  2. Prowhiz
    Honeycomb Jun 3, 2017
    Prowhiz , Jun 3, 2017 :
    Yes. Eventually the sides get weak and dust particles get in. I'm using Orzly TGSP with Spigen Rugged armor case. But so far my device has been well protected with the combination. Just the annoying dust particles.
    Ranjithsmart likes this.
  3. Harshathz
    Cupcake Jun 3, 2017
  4. Richie Peter
    Froyo Jun 3, 2017
  5. Ranjithsmart
    Jelly Bean Jun 3, 2017
  6. abhishekgoyal306
    Eclair Jun 3, 2017
    abhishekgoyal306 , Jun 3, 2017 :
    but man screen protectors doesn't respond well to falls they dnt save your screen from breaking but they can save from small scratches though
  7. jbsf
    Cupcake Jun 5, 2017
    jbsf , Jun 5, 2017 :
    I bought Nillkin 9h and it doesn't cover the edges, plaus the glass is on top of the camera (wtf!)
  8. Esmeralda007
    Gingerbread Jun 5, 2017
    Esmeralda007 , Jun 5, 2017 :
    Got oneplus tempered glass from oneplusstore.in and it fits perfectly. Also touch is working cool and there is no rainbow effect as said. Also I have put MTT case which covered the glass perfectly. Just be careful while covering. That's all. I am happy. :)
  9. Onkar.Singh
    KitKat Jun 5, 2017
    Onkar.Singh , Jun 5, 2017 :
    Nice to note that you are quite happy with the TGSP ... also, the rainbow effect is visible only under certain conditions ....
  10. F_Diganta_Koner_WIXu
    Jelly Bean Jun 5, 2017
  11. lordred12345
    Gingerbread Jun 6, 2017
    lordred12345 , Jun 6, 2017 :
    its a good deal but id recommend the tempered glass from Orzly
    Ranjithsmart and niijonodhg like this.
  12. imtiyaz1
    Cupcake Jun 6, 2017
  13. Ranjithsmart
    Jelly Bean Jun 7, 2017
    Ranjithsmart , Jun 7, 2017 :
    It is not a tempered glass it is a plastic flim bro! Now will you recommend me?
  14. Black River
    Cupcake Jun 7, 2017
    Black River , Jun 7, 2017 :
    Is there an alternative for the original black screen protector? Everything I found was cheap glued protectors with oily spots in the middle. I tried 3-4..
  15. G_renzo_dela_cruz_ezJw
    Donut Jun 15, 2017
    G_renzo_dela_cruz_ezJw , Jun 15, 2017 :
    try the official one. full adhesive and not a fingerprint magnet. not the curved one tho cause it wont fit on ur rugger armor
  16. F_Hammoud_Aifan_zgvr
    Donut Jun 15, 2017
  17. Arjun P
    Donut Jun 17, 2017
    Arjun P , Jun 17, 2017 :
    it's a white glass right? op discontinued black I guess.
  18. Prowhiz
    Honeycomb Jun 24, 2017
  19. Vanshgoel
    Donut Jun 24, 2017
  20. Khaja hussain 13
    Cupcake Jun 27, 2017
