12
[Temporary Fix] Fix the Mic not working on OOS Pie on 3/3T
  1. DarkSJ1998
    Honeycomb Apr 20, 2019
    DarkSJ1998 , Apr 20, 2019 :
    Hi there!
    If you're here, I hope you're enjoying the newly released OxygenOS Pie Community Build on your OnePlus 3/3T ;)
    But, there's a serious bug which bothers a lot (me atleast)
    Mic doesn't seem to work when earphones are connected in mostly all apps, except the Dialer app. Normal calling is fine, but Mic doesn't work in WhatsApp Calls, Sound Recorder app and in PUBG. I've So, I found a temporary fix for it.
    I started checking all the apps which use the mic & then it striked my mind that it is Google Assistant which keeps listening at all times! So, it seems that in OOS Pie, there's an issue which causes Google Assistant to always occupy the mic. This shouldn't be the case in my opinion as there are a lot of people who use Google Assistant.
    NOTE : It is still a BUG and needs to be fixed. This is only a temporary solution that I found while I was messing up with logs and stuff, to investigate this issue.
    Steps:-
    1. Open Google App.
    2. Press 'More' on the bottom right, and then 'Settings'.
    3. Press 'Voice', then 'Voice Match' and turn 'Access with Voice Match' off.
    It seems there's some issue with the Google App or Google Play Services app that comes pre-installed with the ROM.
    Before disabling this setting:-
    After disabling it:-
    This applies to the 'leaked' Closed Beta build as well as the new 'Community Build'.
    Let me know if it fixed the issue for you! ;)
  2. DarkSJ1998
  3. abidbunny
    Honeycomb Apr 22, 2019
  4. abhibnl
    Ice Cream Sandwich Apr 22, 2019
    abhibnl , Apr 22, 2019 :
    I always disable as many google products as possible on my OOS installations. Google app is the first one to get kicked. I guess that's why I never had that bug when I was on community beta.
  5. Ighy
    Cupcake Apr 23, 2019
  6. nithinelambachi
    Donut Apr 28, 2019
  7. R1552067412176
    Cupcake Apr 30, 2019
    R1552067412176 , Apr 30, 2019 :
    Guys, I am experiencing issue with mic during calls as I perfectly able to hear clear voice of the caller but in turn caller isn't able to hear my voice at times very very low voice with distortion or noise. But if I respond to them by keeping mic area of my 3t quite near mouth or turn on speaker mode then caller is able to hear my voice. Can someone guide on this or share some reliable solution to stated matter.
  8. Pavan1827
    Donut May 2, 2019
  9. sppj
    Froyo May 4, 2019
    sppj , May 4, 2019 :
    Thanks ,,, This fixed my issue of VOIP application when using Bluetooth Headset.
  10. DarkSJ1998
    Honeycomb May 11, 2019
