2
The Headphone jack
Where do you want the headphone jack?
  1. Top
    61.9%
  2. Bottom
    38.1%
  1. T00Sp00kyFoU
    Ice Cream Sandwich Apr 17, 2014
    T00Sp00kyFoU , Apr 17, 2014 :
    What the...... So i should toss my Shure SRH840s for some inferior audio quality bluetooth headphones? Definitely a no thank you.
    #41
  2. only1butfun
    Gingerbread Apr 17, 2014
    only1butfun , Apr 17, 2014 :
    If the drawings are an indication in any way it will be on the top.
    For me it doesn't really matter that much as I'm using bluetooth headphones most of the time.
    Everything is fine with me as long as it's not on the side or covered by a latch as my current phone has it.
    #42
  3. SHM
    Honeycomb Apr 17, 2014
    SHM , Apr 17, 2014 :
    Doesn't matter, just hoping that the noise cancellation is built in, like the Xperia Z2.
    #43
  4. sekreterarN
    sekreterarN , Apr 17, 2014 :
    but i dont have Bluetooth headphones :-(
    #44
  5. clayginn
    KitKat Apr 17, 2014
    #45
  6. CZ Eddie
    Froyo Apr 17, 2014
    #46
  7. Darksidious
    #47
  8. clayginn
    KitKat Apr 17, 2014
    #48
  9. CZ Eddie
    Froyo Apr 17, 2014
    #49
  10. BigStotty
    Cupcake Apr 17, 2014
    BigStotty , Apr 17, 2014 :
    Next to the Usb port mainly just for the design of docks etc
    So it can charge while playing music via speakers
    #50
  11. justyfier
    justyfier , Apr 17, 2014 :
    why should there even be a top or bottom? with on screen buttons that concept will soon be outdated!! just let the phone rotate that way and just put the main camera in the middle.
    #51
  12. Chinda
    Jelly Bean Apr 17, 2014
    Chinda , Apr 17, 2014 :
    Headphone jack will be on the top as the early OnePlus One sketches showed :)
    #52
  13. hardmandx
    #53
  14. pables
    pables , Apr 17, 2014 :
    bottom, the headphone jack should be pointing at you rather than being on top and having to wrap it around the front or back of the phone...
    #54
  15. Toinou
    Toinou , Apr 17, 2014 :
    I always wanted top, but when I use my phone in my car, and I've to charge it too, it more easy if the jack & USB are in the same part of the phone ! :)
    So, bottom :)
    And.. with jack on top, always the wire on the screen when you want to use your phone !
    #55
  16. Ryanpb79
    Ryanpb79 , Apr 17, 2014 :
    Agreed..bottom is the way to go. The cord will be out of the way. Maybe less drops since you don't have to rotate the phone after taking it out of your pocket.
    #56
    pables likes this.
  17. adamq
    #57
  18. Nick Leffler
    Eclair Apr 22, 2014
    Nick Leffler , Apr 22, 2014 :
    They make small adapters that you can plug normal headphones into to make them Bluetooth I think I use that more than the jack. It kinda sucks though because that has a separate battery that you have to charge.
    #58
  19. Nick Leffler
    Eclair Apr 22, 2014
    True but using those it would probably be better to use a USB DAC anyway.
    #59
  20. stuie bedubbie
    Gingerbread Apr 22, 2014
    stuie bedubbie , Apr 22, 2014 :
    Bottom of course..for all the above reasons, an well cause I like to be on top!
    But really I just want a phone to plug the jack into, my arms springing leaks.
    #60
