DESIGN
In the red corner, standing 155 mm tall (6.2 in), weighing in at 176 grams (0.1kg), the flagship killer!
When looking at this heavyweight champion at first glance, I notice straight away that this flagship is made with an all body glass which uses Corning Gorilla Glass 5. What comes to mind when we speak about glass? Ohh a variety of words like fingerprint magnet, fragile, weak, shatterable, protection and I can go on and on.
On the other side of things, an all glass body on a smart phone is what we call nowadays elegance and prestigious. It makes the device feel premium and I do admit that. When I took the device in my hand for the very first time, I had a euphoria feeling which can only be described as stunning.
Let’s take a closer look at the OnePlus 6 and how it presents in the design language to us.
The edges are curvy and a bit rounded with very minimal thin bezels. There is an aluminum frame that encompasses the OnePlus 6 body. On the left side, you will find a SIM tray and volume rockers
On the right side you will find the Alert Slider (on previous OnePlus devices, the Alert Slider was found on the left side) and the Power switch.
On the top, you will find a noise canceling microphone.
On the bottom, you will find a microphone jack (still there) and only a one speaker (wished it had dual speakers)
On the back, there is a dual camera setup and a flash and underneath them a fingerprint sensor
On the front, there is only one thing that stands out and that is (can you guess) – THE NOTCH!
The display of the OnePlus 6 is just ideal for me. The resolution is 1080x2280 but even at this resolution when other flagship phones are coming with Quad HD displays, the display is crisp, bright even at the lowest settings and a pleasure to watch Full HD videos on YouTube. This photo that I took of viewing a picture was set at brightness level 35%
As I wrote in my unboxing review, the glass is so reflective I can see myself in it. In outdoors when the sun is hitting my phone at a certain angle, it tends to blind some people
Joking aside, there is some eye strain if you look at it directly when the sun hits it.
OnePlus has made a bold move to switch up their design on the OnePlus 6 using all glass instead of Grade-A Aluminum Alloy. I must say that the design is gorgeous, eye catching and all that sugar sweet coating that comes after it. The only thing I personally have a hiccup on is glass and the notch.
And here is why.
I had a Samsung Galaxy S6 Edge which was made out of Corning Gorilla Glass 4. I decided to go nude with this phone as it was the first phone which was made out of all glass and wanted to show that puppy off. Unfortunately, one day, my hands were sweaty and I picked out my phone from my pocket and as soon as I did it slipped through my fingers falling flat on its back and hitting the concrete. All I heard was a crack. I picked it up and the glass on the front was ok, but the glass on the back was shattered completely. Getting back to the OnePlus 6, which I mentioned uses Corning Gorilla Glass 5, I believe if I had an accident like that which I mentioned above, it would completely shatter. The good side is that there are cases and tempered glasses that can be used to protect our heavyweight champions
The second problem I have is with the notch. I see why OnePlus wanted to include the notch. The first reason is because it’s becoming extremely popular to have this design flaw (I have to call it that, there is no other way of calling it out) and second reason is because OnePlus wanted to maximize the screen to body ratio, letting users enjoy the screen. The second is a valid reason but OnePlus could've used another design in which the notch would be even smaller than the one they have now and located more at the edges of the screen which will be less visible to the user. There is always a bright side to the notch – after a couple of days you slowly get used to it as I did. Should I get used to it or should I have options? That’s the question that lingers in limbo.
In summary, the heavyweight champion pulls in to the ring slowly. Will the flagship killer prove to us that it’s a GO or only for SHOW?
