31
The Lab - OnePlus 7 Pro edition: AMA
  1. C1554211719895 Cupcake Jun 18, 2019
  2. AnonymousWP The Lab - OnePlus 7 Pro Reviewer Jun 18, 2019
    AnonymousWP, Jun 18, 2019 :
    Nowadays not anymore. I heard a lot of people being afraid of charging their phone at night. If you use trustable chargers (no garbage chargers of 30 cents from AliExpres) then you should be completely fine. I Dash-Charged my OnePlus 3 for 3 years long, every night and it still has 85% battery capacity. Overcharging isn't a thing anymore. When the phone detects it's full, the charger simply stops charging or it's being dissolved.
    Mr West likes this.
  3. dnagpaldg The Lab - OnePlus 7 Pro Reviewer Jun 18, 2019
    dnagpaldg, Jun 18, 2019 :
    There is a survey in the community going on. fill it up.
    C1554211719895 likes this.
  4. dnagpaldg The Lab - OnePlus 7 Pro Reviewer Jun 18, 2019
    No. The charging tech turns off current flow to device when it gets to 100%
    Mr West likes this.
  5. C1560417500535 Cupcake Jun 18, 2019
  6. Aman Saraf Cupcake Jun 18, 2019
    Mr West likes this.
  7. AnonymousWP The Lab - OnePlus 7 Pro Reviewer Jun 18, 2019
    Define 'not working properly'. What about other apps? May be a bug in the app then.
    Well, if you want: can you please test something for me?
    Can you try if this works on the 7 Pro? https://forum.xda-developers.com/oneplus-6t/how-to/guide-mclaren-fignerprint-animation-t3882236. Doesn't require root.
    Aman Saraf likes this.
  8. AnonymousWP The Lab - OnePlus 7 Pro Reviewer Jun 18, 2019
  9. Pritam871 Froyo Jun 18, 2019
    Pritam871, Jun 18, 2019 :
    I have recently bought OnePlus 7pro.
    Why I am still having security patch of April while my phone is upto date with latest version of Oxygen os.
  10. AnonymousWP The Lab - OnePlus 7 Pro Reviewer Jun 18, 2019
    Good question. I also wished we had a more recent one. I think we'll get another update this month though, which will also bring a new security-patch.
    Pritam871 and Bouncer71 like this.
  11. Helder_DAlmeida Gingerbread Jun 18, 2019
    Helder_DAlmeida, Jun 18, 2019 :
    Hi all! My question is :how do you fell using it with the 90 refresh rate and how much long for the battery use on daily basis such as WhatsApp facebook Instagram waze and some gaming experience like asphalt 9? "never settle"
  12. KeepTransisting The Lab - OnePlus 7 Pro Reviewer Jun 18, 2019
    KeepTransisting, Jun 18, 2019 :
    One thing to know about security patches is that one that's a couple of months old doesn't make your phone extremely vulnerable. Many of the exploits found require physical access to the device, or an extremely certain set of steps to be followed. Do the following and you'll be fine:
    1) Keep your device safe. Don't give others your pin. Don't use pattern or face unlock.
    2) Don't install random APKs off the internet. Keep to the play store
    3) Don't go to malicious websites
    Follow those steps and you'll be OK
  13. AnonymousWP The Lab - OnePlus 7 Pro Reviewer Jun 18, 2019
    It feels so much faster and more fluid than my 3. Others I spoke that come from an S10 or OnePlus 6(T) with 60Hz say that 90Hz is a really nice addition.
    Regarding battery life: I'm able to get 6 - 10 hours of Screen-on-Time, with 90Hz/1440p. Evidence is here: [The Lab] A OnePlus 7 Pro review - By AnonymousWP (Updated on 17-06-2019)
    Helder_DAlmeida and Bouncer71 like this.
  14. T1559411301245 Cupcake Jun 18, 2019
  15. AnonymousWP The Lab - OnePlus 7 Pro Reviewer Jun 18, 2019
    You can use Google Drive in combination with OnePlus Switch.
  16. SachinSSG Cupcake Jun 18, 2019
    SachinSSG, Jun 18, 2019 :
    2nd sim slot does not detect any sim[e]1f630[/e]I have inserted sim correctly. tried other sim too.
  17. matthu.2711 The Lab - OnePlus 7 Pro Reviewer Jun 18, 2019
    matthu.2711, Jun 18, 2019 :
    It really does make quite a difference. You don't notice it initially, but I could never go back to 60Hz! For me, battery is alright! some have gotten much better than me, it's all based on personal usage
    Helder_DAlmeida likes this.
  18. srika2512 Froyo Jun 18, 2019
    srika2512, Jun 18, 2019 :
    Hey, I restarted my phone and it disappeared
  19. srika2512 Froyo Jun 18, 2019
    The 90 frame rate is very much noticable since it's really fluid. It just grows on you and like others said I don't think I could move back to a device using 60. i have used it beside a S10+ and it is visible. I use my device for social medical, gaming and maps everyday and get about 5 hrs on screen time. I charge my phone at 7 and by 10 in the evening I'm at about 20 percent. My location and mobile data are always on!
  20. srika2512 Froyo Jun 18, 2019
    True I am on April as well. We have received a lot of updates with respect to the software. As some fellow buddies said as long as you don't share your pin and avoid downloading apks from the internet you should be fine. I'm confident OnePlus will update it shortly. It seems they are working very hard on fixing the camera issues based on the multiple feedback they have received
    Pritam871 likes this.
