32
The Lab - OnePlus 7 Pro edition: AMA
  1. Yatheendra voleti
    Cupcake Jun 19, 2019
    Yatheendra voleti , Jun 19, 2019 :
    NO even though all WhatsApp notifications are turned off still the WhatsApp video call notification is directly appearing on lock screen even it is locked.
  2. B@L@OP7
    B@L@OP7 , Jun 19, 2019 :
    I am not feeling vibration pattern on selecting from one pattern to another. Oly mmm-mm-mmmm pattern i can sense the vibration
  3. C1541308074807
    Donut Jun 19, 2019
    C1541308074807 , Jun 19, 2019 :
    yes it does say warp charging.. and I do use the original cable and brick
  4. AnonymousWP
    The Lab - OnePlus 7 Pro Reviewer Jun 19, 2019
    AnonymousWP , Jun 19, 2019 :
    Oh you mean the screen where you see your contact's profile picture? That's normal and can't be removed/turned off.
    Check the settings. Try something else than 'dynamic'.
    Does the brick get extremely hot?
  5. C1541308074807
    Donut Jun 19, 2019
  6. C1541308074807
    Donut Jun 19, 2019
    no overheating issues
  7. mgriyaz
    Eclair Jun 19, 2019
    mgriyaz , Jun 19, 2019 :
    Pls enable voice dial in OP 7 pro with out the support of Google assistant.
  8. KeepTransisting
    KeepTransisting , Jun 19, 2019 :
    Why? Google Assistant works fine for that.
  9. Yatheendra voleti
    no bro when the screen is locked if u get a video call from WhatsApp its directly showing on the screen I don't need that. for example in an iPhone we can turn off/on content to show in lock screen or not. so that one can answer the call unless when it is unlocked.
  10. KeepTransisting
    You have to contact WhatsApp then. They're overriding your notification settings. That's not something OnePlus can really fix.
  11. AnonymousWP
    Security & lockscreen > 'on lockscreen'.
  12. dnagpaldg
    dnagpaldg , Jun 19, 2019 :
    I got the same results. it could vary a bit based on power consumption while charging it, such as for getting signal etc. but the basic results are the same as we got
  13. dnagpaldg
    try changing the settings. it's under sound/call settings.
  14. C1541308074807
    Donut Jun 19, 2019
    phone was switched off during charging .. and still I got the same results
  15. S4vant
    S4vant , Jun 19, 2019 :
    I have the unlocked (non-Tmobile) version of the Oneplus 7 pro. Awesome phone!
    Is there any way to get the Google Feed when I swipe left instead of the Shelf?
    I came from a pixel and really came to rely on the info from my feed, including appointments, package arrivals, weather, and personalized news.
  16. KeepTransisting
    Nope. That's an exclusive feature to the Pixel Launcher. There are some hacks and mods you can do to get it, but nothing that won't require a bit of tinkering.
  17. Mayur1541
    Mayur1541 , Jun 19, 2019 :
    while the phone is in night mode the lock screen wallpaper got pixeled out and not appear good. can anyone tell the solution.
  18. X1559734999266
  19. AnonymousWP
    Until a certain level, yes. I wouldn't take the risk though. It's more like water resistant, like against heavy rains and showers for example.
  20. G_vishal_gupta_UKHY
    G_vishal_gupta_UKHY , Jun 19, 2019 :
    I had purchased one plus7 pro the very first min. from amazon.in, I was happy to see the build quality. but at the same time found the screen a bit bigger then what I would have liked, due to which I guess it had put in some weight too.
    But their are some issues I found with this phone, now that I have been using it for a month now.
    the camera is a bit wierd, it changes the original colours , also the wide angle camera's quantity was a bit questionable as the edges gets a bit curved effect.
    Also it has some lagging effect using some apps like what's app, etc.
    Also I found that my vibration is not working in neither modes, don't know why!!
