31
The Lab - OnePlus 7 Pro edition: AMA
  1. •Sonubabu• Cupcake Jun 25, 2019
    •Sonubabu•, Jun 25, 2019 :
    Dark mode in OnePlus 7 pro is this normal?is this a convince cause I don't see it that way. It's irritating eye's I hope you guys can see that content. The word's are disappearing and appearing is this normal? Or do I have a very defective panel
  2. tanver.wazir Cupcake Jun 25, 2019
    tanver.wazir, Jun 25, 2019 :
    ok google not working iam unable to on access with voice match nothing happens when I click on it
  3. G_jagdeep_saharan_fSBX Cupcake Jun 25, 2019
  4. KeepTransisting The Lab - OnePlus 7 Pro Reviewer Jun 25, 2019
  5. madhupv Cupcake Jun 25, 2019
    madhupv, Jun 25, 2019 :
    Hi, my phone call quality through car audio Bluetooth is so bad. How to fix it. Media audio quality in the same is good, problem is with the phone call only. Please help.
  6. lakshaydogra04 Eclair Jun 25, 2019
    lakshaydogra04, Jun 25, 2019 :
    i have OP7 pro but why doesnt it have any pochet mode, It really irritates sometimes camera pops up in pocket only?
  7. Sippy_003 Cupcake Jun 25, 2019
    Sippy_003, Jun 25, 2019 :
    hello my WhatsApp widget turns be black at night how do I make it normal please let me know asap thanks
  8. thanoskalk Froyo Jun 25, 2019
  9. Dhruv Weaver The Lab - OnePlus 7 Pro Reviewer Jun 25, 2019
    Dhruv Weaver, Jun 25, 2019 :
    It's because of how the proximity sensor works. They are apparently using an Elliptic Labs proximity sensor which uses a mixture of machine learning and some physical sensor data. This is how they could achieve a fully bezel-less screen without needing a hole for the sensor. So it's probably not reliable enough to implement a pocket mode.
    AnonymousWP likes this.
  10. Meccanica Eclair Jun 26, 2019
    Meccanica, Jun 26, 2019 :
    I use Strava extensively but rarely record activities with my device. I normally use Fenix 5x Plus for running or Wahoo Bolt for cycling, both work perfect with the 7 Pro.
    I tested using Strava app to record some Hill Sprints today after turning off battery optimization it did not drop for me at all. I'm on beta version of Strava with a premium account if it matters. Maybe sign up for beta on Google play store and make sure the new beta is excluded from battery optimization and you don't have deep cleaning of background processes turned on and see if it works better.
    F_Calum_Wardlaw_cwgT likes this.
  11. tanver.wazir Cupcake Jun 26, 2019
    tanver.wazir, Jun 26, 2019 :
    it works after i did following
    1) Disable Smart Lock and Voice Match
    Settings > Security & location > Trust agents > Smart Lock (Google) > turn off
    Settings > Search > Voice > Assist & voice input > Assist app gear icon > Voice Match > turn off all 3 toggles
    2) Restart phone
    3) Enable Smart Lock
    4) Enable Voice Match
  12. O1561147322788 Cupcake Jun 26, 2019
  13. Y1559785397836 Cupcake Jun 26, 2019
    Y1559785397836, Jun 26, 2019 :
    I am not able to see notifications on my Fitbit versa although I have configured notifications for calls and watsapp. it worked fine for few days and later just stopped working.
  14. N1542330547561 Cupcake Jun 26, 2019
    N1542330547561, Jun 26, 2019 :
    I just want your team to improve the camera software better
    because I have both iPhone xs max and OnePlus 7 pro when ever I use video recording I jusr feel like iPhone is more clear and better quality. Over all 7 pro is a good phone compare to s10+ just only the camera is still not clear and high quality for me
  15. N1542330547561 Cupcake Jun 26, 2019
    here is what I know about the phone
    1. FHD+
    2. auto switch
    3. QHD+
    number 2 and 1 is not that much different FHD+ only save you about 2% of your battery anyway. I hope this can help you to decide which one you go with :D
  16. LukaszRudnicki Eclair Jun 26, 2019
  17. Gifton Sundar Donut Jun 26, 2019
    samithahm likes this.
  18. F_Calum_Wardlaw_cwgT Eclair Jun 26, 2019
    F_Calum_Wardlaw_cwgT, Jun 26, 2019 :
    All notifications options on the app are selected
  19. kun_jan Cupcake Jun 26, 2019
  20. arsalan.aarib Donut Jun 26, 2019
    arsalan.aarib, Jun 26, 2019 :
    I am facing problem with proximity sensor and adaptive Brightness sensor. they don't seem to work efficiently. Device- One Plus 7
