@elanglois @Krishrox ,
There is a cooling system on the phone, and it works properly. How many layers, I think that's addressed properly.
The cable provided is USB 2.0, but the port is USB 3.1 . That's what the documentation with the phone says, OnePlus doesn't hide that. The Warp charging standard provides extra power by adding more pins for power delivery in the cable. That's why, using the cable provided in the box, you will get USB 2.0 speeds only. If you want faster speeds, try a USB 3.x cable.
The camera lens is 78mm and has 3x lossless zoom. I can confirm that it is not all optical, because trust me that's the first thing I checked as soon as I read about this thing. But even then, the overall image doesn't lose any detail so I'll say it works as advertised. Yes, I'm letting them out on a technicality, but that's because we're used to lossless zoom being optical zoom and OnePlus played around with that.
Y1537540350852
hey, anyone checked the SOT WHEN display is set to 60Hz .since I've heard from many users that ON average SOT OF 7 PRO IS AROUND 4.5 AT BEST SINCE 90Hz display and Quad Hd display uses battery extensively... Anyone try using at 60hz since 4000mah gotta run through whole day!!!
I'm using it at FHD+ 60Hz for two days now, and I've seen that it lasts me around 6 hours 30 min SOT with a lot of background apps and camera being used and full brightness all the time. It lasted me a day like that, with around 20% left in the end. If you use it at 50% brightness, usage will increase drastically.
The SOT at QHD+ 90Hz is not really much lower for me, around 1
hour, but then 90Hz is something you don't want to lose out on. Try FHD+90Hz if you want.
I think the reason for the large battery drain is because of the automatic brightness settings. I find them to always keep the bar very close to the top and often need to bring them down. I hope OnePlus issues an update soon to fix it.
