57
The Lab OnePlus 8T Review by trackstarMKVIII
  1. trackstarMKVIII
    The Lab - OnePlus 8T Reviewer Oct 27, 2020
    trackstarMKVIII , Oct 27, 2020 :
    Thank you so much! I wanted you all to be able to feel the phone in your hand through my words!
    Chenrichy likes this.
  2. trackstarMKVIII
  3. trackstarMKVIII
    Very good description. The gaming is so dope!
    CharlieAlpha9 likes this.
  4. trackstarMKVIII
  5. trackstarMKVIII
  6. hafizabdullahshaikh
    Cupcake Oct 27, 2020
    hafizabdullahshaikh , via OnePlus 6T , Oct 27, 2020 :
    I want to both option in OnePlus 9 because in display finger print not good performance when finger wet
  7. trackstarMKVIII
    What way? What was not good?
  8. trackstarMKVIII
  9. trackstarMKVIII
  10. trackstarMKVIII
    Thank you, yes it does. Hopefully we get some better camera hardware.
  11. trackstarMKVIII
  12. A1571892050147
    Eclair Oct 27, 2020
  13. trackstarMKVIII
  14. trackstarMKVIII
    If you're using the 48M lens the file will be 6000x8000 if you use the 12M lens is will be 3000X4000. The photo quality is higher if you use the primary lens.
  15. trackstarMKVIII likes this.
  16. trackstarMKVIII
    Yes that's a very good point. a valid concern period apparently it should be able to last 800 charges
    G_Shalen_Mhatre_cflP likes this.
  17. trackstarMKVIII
    My recommendation is not charging it to 100% a lot. if I'm using it during the day and I know I'm near my charger I won't charge it to 100%, I'll have it at 70 or 80 and then if I'm going to recharge it again I'll put it to about 95 never a hundred since it's unnecessary
  18. dnagpaldg
    The Lab - OnePlus 7 Pro Reviewer Oct 28, 2020
