22
[The Lab] Romain Cudon's OnePlus 6 Review
  1. Romain Cudon
    The Lab - OnePlus 6 Reviewer Jun 15, 2018
    Romain Cudon , Jun 15, 2018 :
    Well that's what you'd get for $300 more when buying: longer support for you phone (amongst other things surely). At launch, the iPhone 6, 64GB was $750.
    #41
  2. ashishjain03
    Eclair Jun 15, 2018
    ashishjain03 , Jun 15, 2018 :
    so it means buying an iPhone is worth it as they provide support for your device longer than buying a oneplus at a cheaper price because they don't provide support after an year or two. in this way they both cost same.
    #42
  3. Romain Cudon
    Actually yes, it is a way to see things! Not saying it is good or bad. Maybe that buying a OnePlus phone is better for people more encline to changing every 2 years or more while going Apple for example is more relevant for people aspiring to keep their phone for longer...
    #43
  4. ashishjain03
    Eclair Jun 15, 2018
    well I'll agree with you on this one but not even 2 years less than that haha [e]1f602[/e] [e]1f602[/e].
    #44
    Romain Cudon likes this.
  5. Sujith
    Cupcake Jun 16, 2018
    Sujith , Jun 16, 2018 :
    Hallo this is sujith from kochin can you help me pls ... How to take screenshots on one plus six
    #45
  6. Romain Cudon
    The Lab - OnePlus 6 Reviewer Jun 16, 2018
    Romain Cudon , Jun 16, 2018 :
    Hey! You can swipe directly on your screen with three fingers or you can press the power button and the down volume button simultaneously!
    #46
    Sujith likes this.
  7. Sujith
    I will swipe it will not working but power button and the viliyum key this option is wirking
    #47
  8. Romain Cudon
    Ok, so if you want to activate it you can go to settings > gestures and there you have the toggle to activate the three fingers screenshot feature!
    #48
  9. Sujith
    Thank you so much it's working now thank for your support
    #49
  10. Romain Cudon
    You're welcome!
    #50
  11. Dixonmr
    Eclair Jun 17, 2018
    #51
  12. Romain Cudon
    The Lab - OnePlus 6 Reviewer Jun 17, 2018
    Romain Cudon , Jun 17, 2018 :
    Thanks!! I'm happy it helped!
    #52
    Dixonmr likes this.
  13. O1528812709690
    Cupcake Jun 18, 2018
    O1528812709690 , Jun 18, 2018 :
    Hai Sir,
    I just want to ask about that widget in your home screen.
    what app do you use?
    That's weather widget looks good for me.
    Please reply me as soon as possible.
    Thank you.
    #53
  14. Romain Cudon
    The Lab - OnePlus 6 Reviewer Jun 18, 2018
    Romain Cudon , Jun 18, 2018 :
    Hi @O1528812709690 , this is from the Weather Timeline app, it looks great, there are several widgets that requires some customization to make them look like this (transparency settings, icons, colors…) so you should find what suits you best!
    #54
    Crystal Z. and O1528812709690 like this.
  15. O1528812709690
    Thank you Sir.
    By the way,my name is Yunsan.
    Sorry newbie here, I don't know how to chang this account name.
    Once again, Thank you Sir.
    Sincerely yours,
    Yunsan
    #55
  16. Romain Cudon
    Hey Yunsan,
    No problem, you're welcome! If you want to change your name on the OnePlus Forums, I believe that you must do it your OnePlus account, but I must say I am not sure of how it works :)
    #56
    Crystal Z. likes this.
  17. superplus
    Head Moderator Head Moderator Jun 18, 2018
    superplus , Jun 18, 2018 :
    Great read! Thanks for all the info. Loved the pics and videos too! And the animations. One of my main concerns is that I'll miss all the double-tap and long-press shortcuts I've set up. And not being able to reach the notification bar easily indeed.
    Welcome Yunsan, this is correct. Don't forget to log out and log in again for the change to take effect :) Any issues, please feel free to get in touch.
    #57
  18. Romain Cudon
    Thanks for the feedback!
    To be honest I don't miss anymore the double tap to search but I still miss a little the double tap to open the last app and a lot more the double to expand the notification panel. With only one hand it's physically impossible for me to reach the top of the phone without dropping it every other time.
    I really hope that OnePlus has something in store for that!
    #58
    superplus likes this.
  19. superplus
    yes I'll really miss the option to quickly switch back to the last app with a long-press or double tap. and the notification thing, I know I will end up dropping it if I have to do advanced acrobatics like that. so fingers crossed (while not holding any device obviously) for a fix in an update indeed!
    #59
  20. _Stubborn
    Cupcake Jun 20, 2018
    _Stubborn , Jun 20, 2018 :
    Even after having a great configuration of Camera, it is still not up to the mark. My phone's camera could not focus on the objects. The portrait mode is seriously an issue. I am really not happy with it's camera quality. Images are beautified even after disabling the beauty mode. I have installed 5.1.8 and i am still facing this issue. Apart from this camera issue, everything else seems to work fine. Does anybody else facing the same issue? I am posting it here because the link to main forum is broken o_O:(
    #60
