76
The Lab - Unveil the OnePlus 7 Pro Reviews
  1. F_Nikhil_MI_PxBM
    Eclair Jun 16, 2019
    F_Nikhil_MI_PxBM , Jun 16, 2019 :
    well not including headphone jack adapter is a big let down very dissapointed while the cheaper OnePlus 6T had [e]1f44e[/e][e]1f44e[/e]
    Q1562979875458 likes this.
  2. csrcsr07
    Marshmallow Jun 18, 2019
  3. rathore24
    Cupcake Jun 20, 2019
    rathore24 , Jun 20, 2019 :
    When OnePlus 7 Pro (12GB, 256GB) will be available? Currently this is out of stock.
  4. G_Ӄαяαи_ßαкяα
    G_Ӄαяαи_ßαкяα , Jun 20, 2019 :
    PORTRAIT MODE NEEDS IMPROVEMENT.
    In Portrait mode the camera by default uses 3X zoom lens.
    This makes difficult to click pictures in Portrait mode and clearity is also very bad.
    ONEPLUS PLEASE IMPROVE THIS IN NEXT UPDATE.
    S1559415771022 likes this.
  5. Se smile
    Cupcake Jun 23, 2019
    Se smile , Jun 23, 2019 :
    mon oneplus 7pro ne possède pas le langage en français, comment faire pour le télécharger ? comment dois je mi prendre ? merci
  6. T1558753889451
    Cupcake Jun 25, 2019
    T1558753889451 , Jun 25, 2019 :
    Hello there, i was wondering if you would be able to help me with vibration on the phone that are numerous with reasons that i haven't been able to identify. i have gone through the phone set up and remove vibrations but still get them. Any ideas if what should i do to remove them? thanks!
  7. M1558153018451
    Cupcake Jun 26, 2019
    M1558153018451 , Jun 26, 2019 :
    hi everyone one
    actually I have OnePlus 7pro
    I have sim card
    one GSM it's working
    one CDMA doesn't work
  8. M1560637937357
    Cupcake Jun 27, 2019
  9. A1561677755323
    Cupcake Jun 29, 2019
  10. A1561677755323
  11. I1562018969107
    Cupcake Jul 2, 2019
    I1562018969107 , Jul 2, 2019 :
    hi,,thanks for your attention
    i would like to know why there isn't 7pro 12/256 in grey colore & just in blue colore?
    thank you
  12. Mariodew
    Donut Jul 12, 2019
    ErikMcCall likes this.
  13. F1563019684250
    Cupcake Jul 13, 2019
  14. A1563114578783
    Cupcake Jul 14, 2019
    A1563114578783 , Jul 14, 2019 :
    Guys it's been almost 4 days since Ive been using one plus seven. I don't think the battery life is functioning as promised. Is there any customisation which needs to be done? Because it's draining out too quickly
  15. Q1562979875458
    Cupcake Jul 15, 2019
  16. Q1562979875458
    Q1562979875458 , Jul 15, 2019 :
    weird!
  17. MGRRSL
    Cupcake Jul 17, 2019
    MGRRSL , Jul 17, 2019 :
    My OnePlus 7 Pro (RAM:12 GB and ROM : 256 GB) is getting hang eveyday I don't know why?I can't expected it. How can I solve it?
    I bought my phone 30 jun 2019.
  18. Struna
    Froyo Jul 17, 2019
    Struna , Jul 17, 2019 :
    Why is it weird? You can use the older one. Adaptor for 6/6T works well on 7/7Pro. OnePlus let it on you, if you buy the adapter or use the older one. I had to buy it, because it is my first OnePlus phone. Every accessories rises the price of the box. For me it is nonsense that every model of Samsung, for example, has new charger, new headphones, new USB cable in the box. What are people doing with the older one? The usb cables are the same, why it than should be included every time I buy new phone? The same with headphones (if the're with jack). Many people never uses included headphones, because they have BT or their own. I would pack with phone only charger itself and nothing more. This should reduce cost dramatically. For example, Samsung cost >1000 Euro because of AKG headphones in the box, which cost more than 100 Euro itself. Maybe I have wrong philosophy or I am missing something, but unification across all brands (Charging, USB type etc.) would be the best (and also cheapest) solution for all. But everyone wants money and huge revenue, so every brand makes their own accessories, even they are mostly the same. OP is the first phone I have which did not come with adaptor and headphones in it. It gives you an option, which is fine.
  19. F_علي_الشكيلي_
    Cupcake Jul 27, 2019
    F_علي_الشكيلي_ , Jul 27, 2019 :
    أرجو حله مشكلة كاميرا ون بلس 7 برو
    حقيقية الكاميرا مب المستوى المطلوب
    ولا مثل الاجهزة لسنه 2019
  20. F_Nikhil_MI_PxBM
    Eclair Aug 1, 2019
