57
The Oneplus 3 "pocket problem"
  1. siddumm
    Eclair Jan 10, 2017
  2. Fehritail
    Froyo Jan 10, 2017
    Fehritail , Jan 10, 2017 :
    After the Update to OxygenOS 4.0/4.0.1, i get the sane error again. I can still unlock my phone while it is in pocket mode. If i scan a finger it vibrates and unlock.
    The error was fixed while i was using 3.2.8.
    Anyone else?
    G_Lukas_Schramm_wJBV likes this.
  3. dexadrine
    Cupcake Jan 10, 2017
    dexadrine , Jan 10, 2017 :
    I've had the same issue today. OP3 has been fine for quite some time, today its been hot all day, even when idle on my desk and has drained the battery like nobody's business.
  4. Raj_Prince
    Froyo Jan 10, 2017
    Raj_Prince , Jan 10, 2017 :
    Hi all
    I got OP3T 2 days back. Mobile is getting over heated after normal usage for 30 mins. apps used like Facebook, Twitter and WhatsApp. battery draining also too heavy. full charging is completing in 6-7 hours..without watching any vidoes r songs. can u pls help me in this?
  5. Fehritail
    Froyo Jan 10, 2017
  6. JorgeManuelSilva91
    Ice Cream Sandwich Jan 10, 2017
    JorgeManuelSilva91 , Jan 10, 2017 :
    Affects both the 3:
    https://forums.oneplus.net/threads/battery-drain.487176/
    And the 3T:
    https://forums.oneplus.net/threads/one-plus-3-suddenly-heated-up-like-a-hell.487241/
    The fix: Kick Facebook.
  7. G_Martin_Patrick_VBLT
    Cupcake Jan 11, 2017
    G_Martin_Patrick_VBLT , Jan 11, 2017 :
    Just a heads up - upgraded to Nougat - the pocket problem returned as it appears the "pocket mode" switch is disabled by default. Just need to re-enable it.
    @steffen_buus and ghostofcain like this.
  8. Fido228
    Cupcake Jan 12, 2017
    Fido228 , Jan 12, 2017 :
    i have also updated my op3 just now but my works fine i am not facing this problem
  9. airiartev
    Jelly Bean Jan 12, 2017
    airiartev , Jan 12, 2017 :
    my OP3T has that problem... with 4.0.1
    today was burning as hell, the reason was Spotify that was maintaning the device awake...
    bad optimisation Spotify... No FB shit installed
  10. Yashwant Dagar
  11. amitssj
    Honeycomb Jan 23, 2017
    amitssj , Jan 23, 2017 :
    is it fixed or not cause it is still getting very hot.. is there any workaround
  12. schlomm.darmann
    Gingerbread Jan 23, 2017
    schlomm.darmann , Jan 23, 2017 :
    I own a 3T, but I think this does not make any difference.
    Regarding the issue descriped in the first post, at least I can confirm that this issue is still? fixed. If I cover the light sensor while trying to unlock the phone using the finger print sensor, the device does nothing (no vibration which would indicate that the finger print scanner would be used). I would assume that the scanner is correctly deactivated in the "pocket mode".
    So...in respect to your question: Yes - it is (still) fixed in 4.0.2.
  13. olivervbk
    Cupcake Jan 27, 2017
    olivervbk , Jan 27, 2017 :
    Edit: I was wrong.
    I own a OP3, on OxygenOS 4.0.2 and pocket mode was NOT enabled by default.
    And the phone did get freakishly hot when in pocket and the screen is facing my leg.
    You just have to go Settings > Advanced > Pocket Mode and enable it.
    The problem is IS fixed.
  14. ghostofcain
    Marshmallow Jan 27, 2017
    ghostofcain , Jan 27, 2017 :
    Have you all re-enable pocket mode? If it's not working try booting into safe mode and try it again, if not try a factory reset as there shouldn't be an issue with it on this rom.
  15. Sathyaoneplus
    Cupcake Mar 25, 2017
  16. FeiXue
    Cupcake Jul 24, 2017
    FeiXue , Jul 24, 2017 :
    Jesus christ, thank you
    I don't know what idiot thought it would be a good idea to turn this off by default, but that was an idiotic decision, especially given the fact that it had always been on by default previously.
  17. GeekyRohit
    Donut Nov 18, 2017
  18. akks
    KitKat Nov 18, 2017
